Question : Stabilyzer system when Off-roading - what is the correct setup
Doc, You wrote:
"You want that system on for crawling rocks or situations in firm terraine where you may have a wheel off the ground. The system brakes the wheel off the ground and transfers power to the wheels with contact and keeps the truck going foward."
Isn't this the Traction Contol systemjob to do this? When the stabilitrack is off the traction control is still on (I think)
Sorry in advance if this is a stupid question.
Yes. And it is not a stupid question The StabiliTrack uses the antilock brake and traction control technology, to brake the free spinning wheel. Here in N. America, the StabiliTrack and Traction Control are actually separate terms, H3s Auto trans. have both. In Israel, they may be used interchangeably, I do not know. StabiliTrack is and "enancement" system???? It can sense skidding, sliding, spinning tires to help the driver in certains conditions, like on a snow/ice covered road. As I understand it, it can brake the slipping wheel, if your foot is not on the brake, to shift traction. Look at the Owners Manual description:
StabiliTrak
® System (Automatic
Transmission)
Your vehicle may be equipped with a vehicle stability
enhancement system called StabiliTrak
®. It is an
advanced computer controlled system that assists you
with directional control of the vehicle in difficult
driving conditions.
StabiliTrak
® activates when the computer senses a
discrepancy between your intended path and the
direction the vehicle is actually traveling. StabiliTrak
selectively applies braking pressure at any one of
the vehicle’s brakes to assist the driver with keeping the
vehicle on the intended path.
When you first start your vehicle and begin to drive
away, the system performs several diagnostic checks to
insure there are no problems. You may hear or feel
the system working. This is normal and does not mean
there is a problem with your vehicle.
If there is a problem detected with StabiliTrak
®, a
SERVICE STAB SYS message will be displayed on the
Driver Information Center (DIC). See
DIC Warnings
and Messages on page 3-44
for more information.
When this message is displayed, the system is
not operational. Adjust your driving accordingly.
StabiliTrak
® comes on automatically whenever you start
your vehicle. However, when the transfer case is
placed in Four-Wheel-Low Lock mode, StabiliTrak
® is
automatically disabled. See
All-Wheel Drive on
page 2-22
for more information. To help assist you with
directional control of the vehicle, you should always
leave the system on. You can turn StabiliTrak
® off if you
ever need to using the TC (traction control) on/off
button. If you press and hold the TC button for
[left]five seconds, the StabiliTrak[fo
bendyprissy
Feb 22, 2013 05:15 PM
Draketh
May 4, 2011 05:58 AM
No more Jeeps
Jan 11, 2011 05:34 PM
myveryfastgt
Feb 18, 2007 02:51 PM
