Question re cranked TB after Bilstein Shocks install
Old Jun 14, 2011 | 11:23 PM
palmxjjsi's Avatar
Banned
Default Question re cranked TB after Bilstein Shocks install
I cranked my H3's T Bar this morning. 6 full turn on passenger side, 4 1/2 turn on driver side. Came out at 23.5 even. Drove few miles sidestreet, then several miles freeway. Re-measured at flat/even surface. Still at 23.5 even. Before lunch, I took the H3 to a shop and had the Bilstein shocks and 1/2 inch bumpstop from Trail Duty installed. I also got alignment.
I just got home. Re-measured the front. It's now at "24.5"
What happened? Is this normal? I'll just turn it back down to 23.5
Do I need to re-align the wheels?
Old Jun 15, 2011 | 12:16 AM
Yes, by readjusting the torsion bars you have also readjusted the suspensions overall geometry. It's either pay for the alignment now or 2 new front tires (and an alignment) later.
Old Jun 15, 2011 | 04:07 AM
Bullwheel's Avatar
The Bilstein gas shocks will sure add something to the height ...but 1" is a lot.
Other members reported 1/4" maybe 1/2"....
Old Jun 15, 2011 | 06:02 AM
drtom's Avatar
Banned
someone please xplane how shocks change auto height,even 1/16 inch
Old Jun 15, 2011 | 12:10 PM
I have installed the Bilstein shocks on 3 diferent H3s and haven't had this issue.
Old Jun 15, 2011 | 02:04 PM
Sounds like the "shop" adjusted your T Bars to do their alignment (or while doing your alignment) to me?
Old Jun 15, 2011 | 04:01 PM
08JJ's Avatar
I would go with the Doc's answer....I added Bilsteins and never seen an increase.
Old Jun 15, 2011 | 04:25 PM
HawaiianH3's Avatar
Just for discussion sakes, aren't those blisteins gas charged????? If so that could potentially cause lift, but not a whole inch.
Old Jun 15, 2011 | 11:50 PM
drtom's Avatar
Banned
u can look up shocks on wiki or,,,? and see how they work.
since they are all gas "filled" now,gas must be cheaper than air,IF its really gas in there,,,who could possibly know?
if they affect ride height they must be stuck,,defective
Old Jun 16, 2011 | 08:16 AM
The Bilsteins are gas filled to a higher PSI than the stock shock rating, (they fill them with gas at night on the grassy knoll ) that is what gives them some of their stiffer feel, but we are talking appx 10-15 PSI more. The purpose is not to provide lift, but will it raise the front of a 5000# truck???? No.
Grab hold of the front tow rings and give what you think is 20, 30, or even 50# of lifting force....... Did the front raise up? Bust a ball and give it what for and see how far it will raise.
