Question
Old Aug 25, 2010 | 06:11 PM
theboss's Avatar
Default Question
Im having an issue with my truck. I lately been leaving the truck parked at home so i barely use my truck so now every morning i have to turn it on and drive it for at least 30 min or else my battery will be dead could that be a battery problem or the alternator i got the current battery about 2 years ago
Help anyone
Old Aug 25, 2010 | 06:30 PM
Mr. Fancy Pants's Avatar
Do you have a multimeter? If so read the voltage with your vehicle not running. Should be 12 or above. Start the vehicle and read again, should be 13-14vdc. If so both your battery and alter. should be fine. Do you have any accessories that could draw current from the electrical system while the key is off?
Old Aug 25, 2010 | 07:02 PM
bosch's Avatar
Default battery drain
you can buy a clamp on dc volt amp meter that will let you know if something is pulling amps out of your barrey with the eng off ..mike
Old Aug 25, 2010 | 07:43 PM
2wheelmonster's Avatar
or you could take it to a parts store and have them test it for free, buy a float charger or a trickle charger and hook it up
Old Aug 25, 2010 | 07:48 PM
harbor freight sells multimeters for $4. Cheap and nice to have in the toolbox.
Old Aug 25, 2010 | 09:28 PM
theboss's Avatar
just figure out the problem my battery is leaking i did use the meter it just smell really bad thanx guys
Old Aug 27, 2010 | 01:51 PM
theboss's Avatar
Now the new Question do you guys have any idea why my bat is leaking for the second time in less than 2 years ?
