Quality upgraded boot on CV axle
There's been lots of discussion in the past, has anyone found replacement axles complete with the upgraded boot?
Originally Posted by byeatts
(Post 327680)
NEW Cardone Select carries lifetime warranty.. you can get them for around 70 bucks each..
part number 66-1417 both sides.. https://www.cardone.com/Products/Pro...Right%3a%3a%3a |
(Post 327795)
No advice as to the best place to buy replacement CV axle?
(Post 327817)
Post 2008 H3 ACDelco shafts..... best you are gonna do. Ebay, rock auto, etc....
Axle Part Numbers
(Post 327818)
thanks. Are all H3 years the same axle part?
Did you go with the Cardone 66-1417? I ordered them and they were too long and had different splines. JC Whitney said they have had several returned. DTA offers the GM-2580 and have confirmed the length with me so I'm waiting for them to arrive. Duralast Gold CV Axle Part Number: 6417N The GM OEM Part Number is AC Delco 25859867. Detroit Axle has a shaft but it refers to an 8 lug wheel. |
Originally Posted by Kamikazi
(Post 346483)
The H3 and H3T Base, Alpha and X all use the same axle.
Completely untrue statement above. The introduction of the H3 Alpha line in 08 changed the half shaft length (longer in 08-10) and shaft girth (thicker 08-10). So if you buy a remanufactured 06-07 half shaft it will be slightly shorter than the 08-10 shafts. Buy the OEM 15886012 from Ebay, Rockauto.com and others while they last and have YOUR half shafts rebuilt after the supplies dry up. that will be the only way to insure you are getting the longer and beefier half shafts. |
Originally Posted by TAINTER
(Post 346490)
:eek:
Completely untrue statement above. The introduction of the H3 Alpha line in 08 changed the half shaft length (longer in 08-10) and shaft girth (thicker 08-10). So if you buy a remanufactured 06-07 half shaft it will be slightly shorter than the 08-10 shafts. Buy the OEM 15886012 from Ebay, Rockauto.com and others while they last and have YOUR half shafts rebuilt after the supplies dry up. that will be the only way to insure you are getting the longer and beefier half shafts. I may not post much to this site but I have worked as a mechanic and test pilot for many years and know something about inventory and parts research... I have been very thankful for information I have gotten off here but to come out saying someone is making " completely untrue" statement without backing it up is just wrong. So show me the part number for a 2008-2010 that is different that what is for a 2006 - 2008 and I'll shut up. |
I know, never trust the guys who have R&R'd 15+ shafts (some cheap parts store, some ebay, and mostly OEM) in a garage and on the trail that are trying to save your time and headaches. Trust some car parts website that is trying to sell you something.
Check out your other post on the same subject and you will see the photo DocOlds posted. You will see the difference in length and shaft girth. You say you know parts, then you know that some of the parts you listed ARE in fact remanufactured shafts not new. Those remanufactured units can be an outer from an 06-07 and the shaft from an 06-07 and the inner from an 08-10 or any combination in between. The part # did change at least twice 15886012; 15905106. The 15886013 supersedes the previous part due to GM not wanting the expense of having 2 similar parts on the shelf when 1 will fit and service ALL GMT345 HUMMER H3 & H3T applications. |
(Post 346501)
The part # did change at least twice 15886012; 15905106. The 15886013 supersedes the previous part due to GM not wanting the expense of having 2 similar parts on the shelf when 1 will fit and service ALL GMT345 HUMMER H3 & H3T applications. Finally, the change in the part numbers because they didn't want the expense of having 2 similar parts when 1 will fit... It doesn't matter when your Hummer was made, whether it was a Base, an Alpha or an X or a He or H3T.... there is only ONE part number available NOW and they are all interchangeable. So, no my statement was not untrue... I really appreciate this forum for the info it has provided me in diagnosing and making repairs but some members go the luxury route, some go the extreme offroad and some of us are somewhere in the middle... So a $700 part might be extreme for some of our needs while a differential crossmember bushing kit without having to change out the crossmember itself is a doable and cost savings project. In the immortal words of Rodney King... Can't we all just get along?:D |
