Purchased lifted 2008 H2 - Help Needed
Old May 6, 2018 | 09:46 AM
96redvettelt4's Avatar
Default Purchased lifted 2008 H2 - Help Needed
Gentlemen,
I picked a 2008 H2 that has been lifted by a previous owner. Overall the truck seems well taken care of and clean. My question/s have to do with the fabtech Lift. It has upgrade double hoop shocks so it’s not the standard 6” kit listed on fabtech’s website. The truck has 38x13.50x20 Toyos and seems like it could easily fit 40s. Could someone help me out and take a picture and measure of a stock H2 height and tire-to-fender distance gap?
I have a GM 2500HD with a CST 6-8” Lift and my Hummer is easily a couple of inches taller. Basically trying to figure if this thing is cranked up or have some type of body lift in addition to the standard 6” fabtech or is a hummer really that tall to begin with. Any feedback and help is appreciated.
Old May 6, 2018 | 04:33 PM
2003hummerH2's Avatar
If there are gaps in between the bumper and the body then it has a body lift.
Old May 6, 2018 | 05:56 PM
Not sure I’m completely following you. Attached are a couple of pics. From top and center of tire to the center of fender gap is about 13 inches
From the ground to to Center fender trim is almost 51 inches.
Old May 7, 2018 | 08:31 PM
legerwn's Avatar
looks like everything is in the right places, doesn't look like a body lift is installed.
I have an 08 but its not exactly stock height, I have 2" blocks on the rear with 37" tires with 9" between the tires and fender lip. If we take 2" out of the gap for the blocks that leaves 7" then add about 1" for tire difference then we are around 8" for stock height. I quoted the rear as the front can be changed by cranking the torsion bar keys so that measurement may not be accurate.
Neal
Old May 7, 2018 | 08:34 PM
legerwn's Avatar
The area to the right of the shocks where the large wire harness is looks identical to mine and I know for sure mine does not have any lift on it. Thats why I said yours does not have a body lift on it.
Neal
Old May 7, 2018 | 08:42 PM
Neal
Neal,
Thanks for the feedback.
Chad
Old May 8, 2018 | 09:22 AM
legerwn's Avatar
I don't have good pics to show the correct angle,
This was mine when I purchased it, it still had the factory tires at this time.
Old May 8, 2018 | 08:47 PM
Much appreciated. How’s your MPG with the 37s and power feel? I get about 9.5 MPG with the 38 Toyo MT but mine does have a Magnuson Supercharger. I’ve never driven a stock one so don’t have anything to compare to
Old May 8, 2018 | 09:27 PM
legerwn's Avatar
It was sluggish when I first got it even with the stock tires. I put a Diablo Sport tuner and had a fellow (Lew) tune it for me, I do like the way it feels now allot more then before. The truck runs strong for a heavy truck even with the larger tires. I been getting around 10 to 11 mpg with the tires but I think the tune helped here also. The thing would pull timing driving down a flat road prior to the tune but now it rarely pulls any timing.
Prior to installing the tires I figured if I didn't like the power loss I would just find me a set of diffs from an 07 and stick them in as they came with 410 gears an the 08 & 09 came with 370 gears. I really didn't feel any loss of power from the tires but like I said I had it tuned about the same time. I'm still looking for a good deal on a set of diffs from an 07 just to have in reserve.
Neal
dave100500
Aug 10, 2013 04:12 AM
Allterrainblue07
Mar 19, 2013 11:26 AM
Caraddict
Sep 17, 2012 08:28 PM
Det2008SUT
May 7, 2012 12:37 PM
Canesfan
Oct 26, 2005 03:38 PM
