Problem - rough idle and stall 1st start of day only
Old Mar 7, 2011 | 11:23 AM
branstone's Avatar
Originally Posted by Zipthelipp
I doubt its the rings, head maybe. I also have an 06' with over 58k on it and after everything I read about 06's I'm just waiting for my head to go. Anybody here with an 06' without a head issue??? Good luck Branstone keep us posted.......
I had the head rebuilt just a few months ago, compression tests indicates its below the head ( wet test was normal compression ) i will be taking it in to the shop soon.
Old Mar 19, 2011 | 03:51 PM
branstone's Avatar
Default Update !!
so it turns out the #1 cylnder , the rings were bad. so new ring kit, another new head gasket, new rod bearing kit, and labor, $3500, but is giving me a break because he just did the head rebuild 2 months ago, so $2500. and i get it back nxt saturday.
Old Mar 19, 2011 | 09:23 PM
Widespread Hummer's Avatar
I have an 06 with 71K, dont remember the build date offhand, although i think when i looked before I am supposed to be out of the bad range. Nonetheless, I am paranoid about a possible issue and my mind races anytime the engine behaves differently.
Damn Branstone it sucks wen 2500 is a break :eek Not saying its unreasonable, I dont know, just when you had $$$ work done recently. Good Luck
Old Mar 9, 2012 | 07:04 PM
timpossible's Avatar
I've had this problem intermittently on my '08. After reading all this, I'll be taking it in before warranty is up for sure! The thing is, it only happens to me at work, where I park on a slight decline. It's never happened at home.
Old Mar 11, 2012 | 09:49 PM
drtom's Avatar
Banned
it would be interesting to park backwards,,,then see??
Old Mar 17, 2012 | 04:42 PM
mchase's Avatar
I've run into the same issue lately. Happens normally on first start of the day regardless of exterior temperature. Also will happen if i let it sit for more than 2 hours. If i just go to the grocery store and come right back out it starts up fine and wont stutter.
No codes are thrown and i've even heard it backfire once.
My question for the OP is did the expensive engine work fix his problem?
vehicle is an 08 H3 with 56K miles.
Old Mar 19, 2012 | 11:13 AM
branstone's Avatar
yes all fixed and working great now "knock on wood " !!!
Old Mar 19, 2012 | 12:25 PM
midwest's Avatar
I might be in this category too. I also have an '08 that sounds kind of rough upon initial start up, but this is an intermittent problem. Truck has 36xxx miles.
Old Mar 19, 2012 | 09:03 PM
mchase's Avatar
thanks Branstone,
you had no check engine light correct? I'm surprised that I do not have one either as it feels exactly like a misfire. did you notice any lack of power? I do not, it runs great after it starts up. I'll compression test it and post my results here.
Old Mar 25, 2012 | 08:45 AM
mchase's Avatar
did a compression test this morning before it got too hot out. I got 190 psi +\- 5 percent across all 5. pretty stoked that all is well. plugs look like they could stand to be changed. I'll swap them out and see if that helps my situation.
