Power Window Mystery
Old Nov 24, 2014 | 09:57 AM
sgilbride's Avatar
Default Power Window Mystery
99 H1 window question. Windows from the drivers master control raise and lower all windows. All other window switches will not raise or lower. Yes, the drivers master control switch is set to on. I've checked the interior window fuse and replaced it just to be sure, but still nothing. What am I missing?
Old Nov 24, 2014 | 07:23 PM
Indy's Avatar
It's probably the switches themselves. You can pop them out and try to "rebuild" them (they come apart, and you can adjust the contacts). Otherwise buy some new ones.
If you have a working switch, try putting it into a location that doesn't work, and see if that does the trick.
Old Feb 17, 2015 | 04:11 PM
V-tek's Avatar
does your alarm automatically raise your windows? I think I'm having window issues due to the ECM. All of my windows work correct except for one that doesn't work through the switch on the door. But last week that window would roll down everthing time I started the car. Found out my ECM has some bad wiring.
hummerhack
Dec 17, 2014 02:25 AM
Broken Halo
Aug 31, 2011 06:45 PM
cruisin
Feb 6, 2011 04:56 PM
HummerGuy
Jan 30, 2008 02:24 PM
blackstangs281
Jan 22, 2007 12:09 AM
