Power Steering Leak
Old Oct 7, 2013 | 11:36 PM
Hooty-Hoo's Avatar
Default Power Steering Leak
My '07 H3 is leaking power steering fluid. Not a heavy leak but annoying. I can't really tell where it's leaking from. How tough is it to take out the pump and reservoir?
Old Oct 8, 2013 | 12:19 AM
Happy Hummer's Avatar
Is it the rack leaking?
Chris
Old Oct 8, 2013 | 01:55 AM
egroegart's Avatar
Before just taking off parts you should try to identify where the leak is coming from. Once you know what part is leaking then you will know whether you need to remove something to fix or replace it.
Old Oct 8, 2013 | 08:17 AM
RKSmith163's Avatar
Go to your local auto parts store and get UV dye and put it in the system. They have kits usually under $20.00 that include the dye, a uv light source and goggles. You can google it if you don't understand how it works. Good luck.
Old Oct 8, 2013 | 10:52 PM
Hooty-Hoo's Avatar
Thanks for the responses. I don't know where it's leaking from yet, but I think it's from the reservoir or the pump. To tell the truth, it's been so long since I've needed to turn a wrench around an engine, I'm looking forward to getting to it (other than the cost and down time, of course). RK- That's a good idea. Much appreciated.
Old Oct 9, 2013 | 07:44 AM
RKSmith163's Avatar
Your are welcome. I confirmed a rear engine cover leak on my Alpha/Offroad using that technique. It was repaired under warranty and has been okay since. Good Luck
Old Oct 13, 2013 | 11:54 AM
PSE30's Avatar
Im having the same problem leaking at both axel seals cheap fix but a pain to do
lex
Mar 18, 2020 08:58 AM
SafariHummerH2
Jun 9, 2016 12:12 PM
Tram
Jun 29, 2012 12:04 PM
ARonBoard
Feb 1, 2011 10:20 AM
CJ
Oct 17, 2007 11:18 PM
