Power seat problem
Old Jun 19, 2019 | 08:51 PM
Tony4's Avatar
Default Power seat problem
My front drivers seat , switch for the rear side of the lower seat ( up / down) is operating the seat in the opposite direction that i move the switch. It is working the portion of the seat in the full range but in the wrong direction. The passenger seat is working the way it should. Any suggestions, as I Have not encountered this before !
Old Jun 19, 2019 | 09:19 PM
maybe the switch was installed upside down or they swapped the motor wires.
Old Jun 20, 2019 | 09:24 AM
Tony4's Avatar
I have had the vehicle since new, so it would have had to been done at the factory, so i do not think so,
Old Jun 20, 2019 | 10:13 AM
did you ever have the seat heaters serviced for any reason in the past maybe the tech was in a hurry? i do not think the controller logic can just switch like that. but you can always remove the battery power to the truck to reset your systems
Old Jun 20, 2019 | 10:20 AM
Tony4's Avatar
No on seat heaters, I will try and set the memory of the seat to its highest position, then manually lower the seat then hit the memory return button and see if the seat moves in the right direction. Then try your suggestion to disconnect the battery, its possible, let you know
Old Jun 25, 2019 | 09:03 AM
This thread has nothing to do with sights and sounds. What are you talking about..... H2?
Vehicle questions go in the corresponding vehicle section. LMK and I can move it.
Thanks,
Old Jun 25, 2019 | 09:48 AM
if you have an H2 there is a seat module GM update flash to correct switch reversal. it can be flashed with a tech 2. so i guess "the controller logic can just switch like that"
Harleykids
Mar 4, 2019 09:40 PM
Crater
Jan 1, 2013 09:31 PM
Smgcabrio
Oct 21, 2010 03:52 AM
AlaskanSummers
Sep 5, 2010 10:53 PM
Quijy
Oct 20, 2008 07:30 PM
