Power outlet/cigarette lighter question
I recently installed an external XM satellite radio unit in my 2006 H3. It doesn't tie into the factory radio unit. I didn't realize that both power outlets under the temperature controls stay on even when the truck is powered off. This means my XM player will stay on unless I manually power it down. All previous vehicles I have owned have a power outlet that kills the power when the car is turned off. Is there a work around for this?
Thanks in advance!
Thanks in advance!
dont think there is unless you modify it. all in mine stay on. even in the boot. not so much on as the power is able to be supplied form the battery even when power is off. its good i guess..... just means i have to take the GPS out of it everytime i get outa the car or its constantly charging it
Wouldn't be very difficult to find an ignition powered wire and put in a 20 amp relay, controlled by the wire. Make one port ignition controlled and leave the other as is. My Dodge Pickup had a good idea, the fuse for the power port could be flipped to the other side of the holder, and it would change the power from switched to on alla time.
I am having this same issue. Has anyone rewired their power outlet to go off when the car turns off. I want one on all the time and the other wired to turn off w/the car. I can't stand having to unplug the GPS every time I turn off the car.
Thanks,
Jason
Thanks,
Jason
As Debbiejeep said, the only proper way to do this is with an ignition controlled wire activating a relay switch to power the lighter receptacle. It's easy to do. 4 wires coming off the relay. You cut the power wire to the lighter, connect each end to the proper relay terminal, run a ground wire from the 3rd terminal, and an ignition wire from the fourth terminal. You can pull the ignition power from your radio harness, as the relay uses such little current it won't affect anything.
Is there an easy way to tell which wire on the radio harness I need to splice into? I'm a novice w/car wiring but I'm a quick learner w/these types of things. Also do I need any specific type of 20 amp relay or are they all the same (probably a stupid question but want to make sure)? And one other dumb question, what size and type of wiring should I use to do this?
BTW: Thanks for the help w/this!
- Jason
- Jason
- Jason
- Jason
17 months ago Dude, 17 months ago somebody else posted this history.
