Post your mileage vs year
Old Jan 5, 2017 | 03:47 PM
calif phil's Avatar
2006 66k
DesertDog's Avatar
Originally Posted by John Wood
Desert dog, oh no what things are falling apart? I have a couple electrical glitches.
https://www.hummerforums.com/forum/h...ed-help-37278/
Here's my thread, and it was fine until a month after i paid the damn thing off.
Old Jan 5, 2017 | 03:51 PM
mulepic's Avatar
2008 90k
Old Jan 5, 2017 | 06:19 PM
jmorando05's Avatar
04 w/31k miles
Old Jan 5, 2017 | 07:54 PM
Jr's 03 HMMMV's Avatar
wow some low mileage her.
03 - 256,000 mostly interstate.
Those little gremlins are starting to wear on me.
Old Jan 5, 2017 | 11:21 PM
H2duramax's Avatar
2008 140k on the chassis and 90k on the duramax
Old Jan 5, 2017 | 11:23 PM
H2Miami's Avatar
256k and the gremlins just start to show up. You are a lucky guy. I've been dealing with them for a while
Old Jan 5, 2017 | 11:52 PM
Don't get me wrong I had my share while in the Army but I was younger. Now that I retired and aged those things are really getting under my skin. That doggone corner marker leak. All of this time no prob, fast forward to last week. I almost drowned, shortened out my audio converter. If you read my newbie post it was a lil rave.
But I still love the ride. ive come up with the 100% corner marker fix. However I did consider spraying the entire rig with Flex Seal!
But seriously at my age if it ever leaks again I will remove the lights take it to a body shop and have the sunroof and lights all covered with steel, then I will mount markers the way fm should have.
After the leak I joined because I didn't have a clue what happened. Learned real quick from the site.
Old Jan 6, 2017 | 12:56 AM
H2Miami's Avatar
Try this .
Silicone on the light plug and wire . I found when the chanel for the rain run is dirty the water levels rinse below the light finding his way in thru the plug
Old Jan 6, 2017 | 07:40 AM
Try this .
Thanks, as a perfectionist and not wanting it to ever leak again and as a boater I took the repair to another level. As soon as I get the part name of the item I used I will post up the how to.
I basically inserted a device that created a lip around the hole first inserted the wire through and the filled it up with the 2nd best Marine grade underwater silicone. I don't expect it will ever leak and the plastic fitting I used will not shrink as the oem grommets did.
I used this site to help identify the problem and just went above.
