please....need help ASAP
Old Mar 2, 2015 | 03:13 PM
CurtisP87's Avatar
Default please....need help ASAP
Im trying to change my wheel bearings. I got all the way to the hub/bearing assembly, and its seized on to the steering knuckle something fierce, which is pretty common from what I've read. So I got out my three-jaw bearing puller, and started getting at it. Well, its so stuck on there that I sheared off one the arms on my bearing puller before the bearing came loose.
I've checked and double checked that I didnt miss a bolt or something, but I cant imagine the bearing being THAT stuck...I took off the axle nut, and the 3 bolts connecting the bearing to the knuckle. Am I missing something here? I dont know what to do...My trucks sitting on jackstands in the driveway, I cant get it to a shop...I've got to get this bearing off, and I'm up sh*t creek without a paddle, or even a raft.
If anybody has any ideas for me, I'd be eternally grateful...
Edit: I took my puller back to the store where I got it, convinced them that it was defective and got a new one. But as I work the puller, its just forcing the stub shaft out through the back of the hub assembly, and I'm worried I'm going to damage the shaft, or worse the differential or something...At what point does the shaft stop going deeper into the diff and the bearing start taking the brunt of the force? What am I doing wrong here....?
Old Mar 2, 2015 | 04:32 PM
ollied's Avatar
soak with bp blaster make sure 3 bolys are out beat the h++l out of it with a 5 lb hammer it will come loose Just changed mine It hellps if you have on lift ,easier to hit
Old Mar 2, 2015 | 06:39 PM
CurtisP87's Avatar
but will the stub shaft eventually stop being forced out the back of the hub, or will it eventually just pop out? I've soaked with PB, beat the old hub like it stole somethin from me...I feel like I might be able to pull it off now, but I'm really worried about the stub shaft, its been forced back a lot.
Old Mar 2, 2015 | 07:58 PM
woodwardsh3's Avatar
see if your auto parts store has a slide hammer [axle puller} an have them show you how to attach it. they work very well, the stub shaft should pop out once the bearing is remove.
Old Mar 2, 2015 | 08:18 PM
CurtisP87's Avatar
So, to make sure we're clear...I should force the stub shaft out the back of the hub, opening the hole in the middle of the bearing, then use the slide hammer to force the bearing off?
It wont damage the stub/axle shafts or my differential to force the shaft out that way?
Thanks for the input, I'm beating my head against the wall with this project. This should have been a 45 minute job and I've spent a day and half just trying to get this damn bearing off. And I haven't even got started on the other side....
Old Mar 3, 2015 | 11:03 AM
NO the stub will not go all the way back, The slide hammer bolts to the 3 lug nuts on the hub, just like the wheel. now use the slide hammer and bang away it will come off
Old Mar 3, 2015 | 11:05 AM
youtube it there should be a video
Old Mar 3, 2015 | 11:34 AM
CurtisP87's Avatar
Oh ok, I see what youre saying. I've only seen slide hammers that go inside the bearing hole then spread out to grab on to it, didn't know they had an attachment to bolt onto the hub.
Thats an excellent idea, I'll see if I can track on of those down. Thank you very much!
Old Mar 3, 2015 | 12:41 PM
This method works. Use 2 fof the bolts on opposite sides.
Old Mar 3, 2015 | 10:20 PM
CurtisP87's Avatar
Well, I finally got that SOB off of there. Well, I didnt, but someone did....
I ended up having to take the entire knuckle off with the bearing still stuck in it. I took it to a machine shop near my house, and they were nice enough to put it on a press and work it out (for a fee )
It took a 12 ton shop press to get that bearing out...Now to tackle the other side tomorrow, fingers crossed that one isn't so stuck.
