Passenger Door Ajar
Old Jul 6, 2011 | 12:01 AM
Traciemw's Avatar
Angry Passenger Door Ajar
For about 3 weeks I have had to deal with this VERY annoying issue. "Passenger Door Ajar" message displays on the dash panel, the interior lights flash on and off, the warning chime comes on and off, and the doors try to unlock. I took it to the dealer who stated that I needed a door lock actuator. I had the passenger side replaced. $250 later, the problem was not fixed. I had the driver side actuator replace. $250 later still not fixed. I read through some forums which stated that BCM may be the problem. $1,000 later, I just drove off the dealer's lot and guess what...the problem is still not fixed. What now?
Old Jul 6, 2011 | 12:02 AM
Traciemw's Avatar
Forgot to add, this is a 2004 H2
Old Jul 7, 2011 | 10:34 AM
GMCustomerService's Avatar
I would be happy to look into this further for you. In order to do so, I will need some more specific information from you. If you could please send me your full name, address, phone number, the VIN for the vehicle, current mileage, and dealer name via private message or email, I will be able to take further steps. Thank you again and I look forward to hearing from you.
Tricia, GM Customer Service.
Old Jul 7, 2011 | 10:48 AM
Muddydawg75's Avatar
Peggy, didn't you learn your lesson at the other forum??
You are worthless and help nobody, even the rubes dumb enough to give you their full name, address, and VIN.
Old Jul 7, 2011 | 10:54 AM
beitodesstrafe's Avatar
Ahahaha!
In regards to the original post... I've got to ask the question...
Did you try shutting the passenger door?
Old Jul 7, 2011 | 12:58 PM
I'm not an H2 guy by any means. Do they have door pin switches? If so replace the $10 part and see if that is your issue.
Either way it sounds like whatever sends the door ajar signal to the light/BCM has the issue. If you can figure out what sends the signal (pin switch/ground/etc) you may be able to solve the problem. The "flicker" you get is due to a bad contact that is open then closed and open again.
Old Jul 7, 2011 | 07:55 PM
Caraddict's Avatar
So Gmcustemerservice is just fishing for people's info & vin number? that's just pathetic!
Old Jul 7, 2011 | 10:18 PM
yeah... then she tells you to call the dealer... and in this case the dealer has already socked the dude for a grand and has not fixed jack ****... hence why he is here... and why forums exist...
It's going to be a cold day in hell before I take my deuce to a pimple faced UTI grad with a couple ASE patches....
Old Jul 11, 2011 | 09:58 PM
Gleamor's Avatar
I was hopeful peggy would stay on the other forum, I see peggy finally made it here.
Well it wont take long before the ban hits again
Old Jul 11, 2011 | 10:19 PM
SUTUFF's Avatar
ROFL...obviously Peggy is going thru the ...retraining... here on HF! Maybe eventually she will get the message!? If not..maybe a bigger rolling pin!
