P0128 reading on 2006 H3
Old Jan 4, 2012 | 07:05 AM
ericksos's Avatar
Default P0128 reading on 2006 H3
Check engine light just came on the other day, got it read and shows P0128. Coolant Thermostat (coolant temperature below thermostat regulating temperature).
Any suggestions for what might be wrong?
Temperature gauge still reads normal temps and the interior heat is working fine as well.
Old Jan 4, 2012 | 07:53 AM
58Bisc's Avatar
In my case it was the thermostat. The first time it happened, we found the cracked radiator. Replaced it and thought we were good. About a month later, started throwing the code again. Replaced the thermostat and it is gone. H3 showed no signs other then the code.
Old Jan 4, 2012 | 10:35 AM
bigdog100's Avatar
Mine did the same thing, I replaced thermostat code went away. However, a week later chk engine light did not come back but digital display says check system been going on and off for a year. Only when temp outside drops below 75.
Old Jan 5, 2012 | 08:09 AM
ericksos's Avatar
Thanks, how easy/difficult would it be to replace the thermostat myself?
Old Jan 5, 2012 | 10:12 AM
bigdog100's Avatar
I had a mechanic do it, however I did watch him and he took off driver side tire and wheel well skirt to get to it. Took about an hour.
Old Jan 5, 2012 | 11:46 AM
58Bisc's Avatar
I to paid the dealership (used my GM points to get it for free). There is a thread that ended on 12/30/11 that explains where it is and how to replace it. I don't know how to insert the link or I would for you. Either look back by dates or search on thermostat.
Old Jan 5, 2012 | 02:12 PM
BERULAKIDE
Jun 25, 2014 07:12 PM
tekstyle
Oct 21, 2013 02:15 AM
Matthew C. Powell
May 1, 2013 01:06 PM
giant H2
Sep 28, 2009 05:14 PM
LawWyfe
Feb 4, 2007 12:44 PM
