Old Leaky strikes again....
Old May 11, 2008 | 10:05 AM
  #31
Trey124's Avatar
Default RE: Old Leaky strikes again....
I'm guess I'm either going to move or have GM build me a carport over my driveway.[:@]
Old May 11, 2008 | 10:10 AM
  #32
rhill20's Avatar
ORIGINAL: Muddydawg75
as long as the loaner isn't slate blue... you should be ok....
That's true, both of mine are black
Old May 11, 2008 | 10:12 AM
  #33
Muddydawg75's Avatar
The house across the street from me is for sale.....
wontcha be my neighbor...
Old May 11, 2008 | 03:20 PM
  #34
alphadogg's Avatar
Yea but, is the driveway flat??? Inquiring minds want to know.
Old May 11, 2008 | 04:24 PM
  #35
yes... very much so...
Old May 11, 2008 | 06:33 PM
  #36
Maybe even have a garage big enough for his Hummer
Old May 12, 2008 | 01:57 AM
  #37
Trey.......Were your WINDOWS CLOSED?????[8D]
Old May 12, 2008 | 01:59 AM
  #38
Isn't Impy thinking of MOVING????
Old May 12, 2008 | 07:10 AM
  #39
Trey124's Avatar
I knew someone was going to ask that, HummBob.[:@]
Old May 13, 2008 | 06:59 AM
  #40
Trey124's Avatar
Well I got my H3 back from the dealer Monday, here's what they found:
Found: Rear seat cushions soaked, headliner soaked, and carpet under seats soaked.
Removed Headliner and found MULTIPLE Leaks.
Leaking thru Left Roof Rail Nutcerts, leaking past sunroof end cap, found left rear sunroof drain hose crushed bu headliner foam block pressing airbag curtain up and colapsing sun roof drain. Installed new drain and test and found still leaking. Removed sun roof and end cap, found end cap seal warped and water leaking thru. Replace seal and put sunroof back in. Remove and seal roof rail bolts and reinstall roof rail and a pillear ext. trim.
I'm posting this in hopes that this helps someone else. After 5 times of me pointing to the roof rack bolt that was I told them was where the water was leaking and 4 previous times told me they found no leak there. Wow this time they found it was leaking right where I've been saying all along. And on top of all this I got my truck started to pull away and saw that my spare tire cover was missing. So I turn around drove back into the service department and I ask where is my tire cover. So smart a$$ little detail kid tried to tell me that I didn't bring it in with one on it. Now I ask you why the F*** would I lie about a spare tire cover that advertises your Hummer Dealership?! So they got me a new spare tire cover from the Parts Dept. just to get me out of there this one doesn't fit as well as the old one did.
