Ok, Which Wire is it?
Old Sep 11, 2007 | 09:08 PM
kosaic's Avatar
Default Ok, Which Wire is it?
I'm wiring a Sirius radio in my 2006 H3.
I know that the Orange on the back of the factory radio harness is battery (always on I believe) and the black/white is ground ...
Which wire is it that stays "hot" when you turn the key off, and then turns itself off when you open the door ? (Thats the obvious one to hook the sat. radio up to)
Thanks in advance.
David
Old Sep 11, 2007 | 09:12 PM
blackstangs281's Avatar
Default RE: Ok, Which Wire is it?
I don't have the wire codes, but couldn't you use a circut tester?
Old Sep 11, 2007 | 09:24 PM
kosaic's Avatar
yes, but I'm in the process of moving and ALL my tools are in storage .. just thought if I could get a quick answer here, would save me from buying tester #3
D
Old Sep 11, 2007 | 09:32 PM
I think Import has some wire diagrams.........should be along shortly
Old Sep 11, 2007 | 09:33 PM
BTW.......Moving SUCKS[:'(]
Old Sep 11, 2007 | 09:34 PM
R u guys helpless?
If it has monsoon
Battery ORANGE (+) RADIO HARNESS
Accesory
Ground BLACK/WHITE (-) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) DARK GREEN
RF Speaker (+) LIGHT GREEN
RF Speaker (-) ORANGE/BLACK
LR Speaker (+) BROWN
LR Speaker (-) DARK GREEN/WHITE
RR Speaker (+) DARK BLUE
RR Speaker (-) BLACK
Amp Location LOCATED BEHIND THE TRIM IN THE LEFT SIDE OF CARGO AREA NEXT TO SUBWOOFER.
Steering Cntrls OPTIONAL
Speed Cntrl YES
Radio Security YES
If it has standard audio
Accesory
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (-) DARK GREEN
LR Speaker (-) YELLOW
RR Speaker (-) LIGHT BLUE
Speed Cntrl YES
Radio Security YES
Do this help?
Old Sep 11, 2007 | 09:36 PM
kosaic's Avatar
I dont mind moving (5 times now in 5 years) ... What I really miss this time is no garage while in between houses and my tools (ALL 3 chests of them) are all stored.
I've got a multi-screwdriver and a 5.99 socket set to deal with
Old Sep 11, 2007 | 09:38 PM
I wish I could type faster, I figured Importkiller was gonna beat me to that one. If you have questions, he's Da Man in this department, not me!!!!!
Old Sep 11, 2007 | 09:39 PM
kosaic's Avatar
Nope ... I knew that much (I found that info posted somewhere earlier) But thanks for sure !
I'd like to know which power wire in the harness stays powered up when the key is turned off and taken out, but turns off when the door is opened.
Just need to figure out that one wire
Old Sep 11, 2007 | 09:57 PM
Would a door wiring diagram work??? The windows still work after the key is off til the door is opened? If you have MS word, I can point you to that.
