Ok, Which Wire is it?
I'm wiring a Sirius radio in my 2006 H3.
I know that the Orange on the back of the factory radio harness is battery (always on I believe) and the black/white is ground ...
Which wire is it that stays "hot" when you turn the key off, and then turns itself off when you open the door ? (Thats the obvious one to hook the sat. radio up to)
Thanks in advance.
David
Thanks in advance.
David
R u guys helpless?
If it has monsoon
Battery ORANGE (+) RADIO HARNESS
Accesory
Ground BLACK/WHITE (-) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) DARK GREEN
RF Speaker (+) LIGHT GREEN
RF Speaker (-) ORANGE/BLACK
LR Speaker (+) BROWN
LR Speaker (-) DARK GREEN/WHITE
RR Speaker (+) DARK BLUE
RR Speaker (-) BLACK
Amp Location LOCATED BEHIND THE TRIM IN THE LEFT SIDE OF CARGO AREA NEXT TO SUBWOOFER.
Steering Cntrls OPTIONAL
Speed Cntrl YES
Radio Security YES
If it has standard audio
Accesory
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (-) DARK GREEN
LR Speaker (-) YELLOW
RR Speaker (-) LIGHT BLUE
Speed Cntrl YES
Radio Security YES
Do this help?
If it has monsoon
Accesory
LF Speaker (+) TAN
Speed Cntrl YES
Radio Security YES
Accesory
LF Speaker (+) TAN
LF Speaker (-) GRAY
Speed Cntrl YES
Radio Security YES
Do this help?
I dont mind moving (5 times now in 5 years) ... What I really miss this time is no garage while in between houses and my tools (ALL 3 chests of them) are all stored.
I've got a multi-screwdriver and a 5.99 socket set to deal with
Nope ... I knew that much
(I found that info posted somewhere earlier) But thanks for sure !
I'd like to know which power wire in the harness stays powered up when the key is turned off and taken out, but turns off when the door is opened.
Just need to figure out that one wire
(I found that info posted somewhere earlier) But thanks for sure !I'd like to know which power wire in the harness stays powered up when the key is turned off and taken out, but turns off when the door is opened.
