OIL Questions
Old Oct 15, 2007 | 12:06 PM
HumV's Avatar
Default OIL Questions
i know 5w-30
But do i use sinthetic semi or regular?
how many quarts?
My First time changing my oil and doing it on my own as well
Any aDvise?
Old Oct 15, 2007 | 01:21 PM
alrock's Avatar
Default RE: OIL Questions
HumV - you've asked some good questions to which you'll find a lot of answers within the forums.
Advice - use Search function here. Also- click here. https://www.hummerforums.com/m_72105/tm.htm. And here. https://www.hummerforums.com/m_67031/tm.htm
[/align]
Old Oct 15, 2007 | 01:55 PM
I like this one, it has pictures!!! H3 Oil Change with Pictures I will make one suggestion based upon my observations. When you remove the drain plug, have your drain pan in your free hand lifted up close to thedrain holeway over to the side towards the driver side front tire. That stuff comes out sideways at first and can make a big mess if you are not ready for that. After the first quart or two, you can set it down and be ok.
Old Oct 15, 2007 | 02:03 PM
This one is informative, but pretty funny too. RE: can someone look in the manual for me?
Old Oct 15, 2007 | 03:07 PM
HumV's Avatar
Looking in the previous forums i am going to go with sinthetic oil
Thanks guys
Old Oct 15, 2007 | 04:17 PM
hilljob26's Avatar
i like a synthetic blend,its cheaper then full synthetic,but better then conventional
Old Oct 16, 2007 | 01:35 AM
h3carlos's Avatar
or so you think
Old Oct 16, 2007 | 10:37 AM
Marcus's Avatar
ORIGINAL: HumV
i know 5w-30
how many quarts?
Any aDvise?
My advice would be to spend the money and get yourself a service manual for your Hummer from Helm, Inc.
Old Oct 16, 2007 | 05:47 PM
f5fstop's Avatar
Regular or synthetic, but synthetic blend is a waste of money. Once you mix synthetic with regular, the benefits of synthetic are void.
Old Oct 16, 2007 | 06:17 PM
bonzaiii's Avatar
I went with synthetic for the first time. I also changed my own oil for the first time in MANY years. It really was a breeze, probably 30 min. tops and I was not in any hurry. Probably spent more time cleaning up after than actually doing the work.
