Oil pressure gauge?
Old Dec 5, 2009 | 09:08 PM
hoffman's Avatar
Default Oil pressure gauge?
Hello All,
I need some help with my 04 H2. Tried search but no follow ups on threads from posters. So here is my issue.
The Oil pressure gauge is stuck on zero. The oil level is good and drives ok. No other service lights on and the oil is reading at 94% good. Has anyone else incountered this and if so what was the cause and fix?
Thank you
Old Dec 7, 2009 | 03:39 AM
easy610's Avatar
1. - Oil sending unit is ka-put...
2. - You've lost a ground somewhere so the gauge isn't getting power...
If under warranty should be a simple fix by stealership.
Perhaps someone with more HUMMER mechanical knowledge will happen along and give more info...
Cheers,
Old Dec 7, 2009 | 08:44 AM
tasco's Avatar
Yup, it's the sending unit, or it's the gauge.
Old Dec 7, 2009 | 07:40 PM
hoffman's Avatar
Thanks for the input. Anyone know where the sender switch is located? Any pics? I have no clue..
Old Jan 15, 2010 | 01:09 AM
dagwood928's Avatar
Just had that happen to my 2003 H2 at 30,000 miles. Also speedo started acting up. Turns out it was the instrument cluster itself. Had it removed and fixed. (under warranty of course!)
Darren
Old Jan 15, 2010 | 01:09 PM
BIGT2148's Avatar
if it is a cluster, be prepared for a big bill. Those things are not cheap. They just act like they are.
Old Jan 26, 2010 | 12:18 PM
green_LUX_HUMMER's Avatar
Default Same gauges for other GM vehicles?
I had a 2005 yukon xl with the same gause issue, turns out that gm knows about it and it is very common for these, if of course, it is the same. I had to fight gm to fix it because at that time they were only recalling 01-04 05 & up were under investigation! Good luck!
Old Sep 30, 2011 | 02:43 PM
Britro's Avatar
I had my instrument cluster repaired by myairbags. Been working ever since
Old Nov 28, 2011 | 01:56 AM
madmike's Avatar
Banned
Mine is stuck at 80. No issues except for the needle. Very annoying and probably the gauge.
Old Nov 28, 2011 | 10:25 AM
Indy's Avatar
If the needle is stuck at 80, it is most likely the oil pressure sensor. It is really hard to get to and I wish they put it somewhere in the front, like they did with my Jeeps. You can't even see it on the H2...maybe somebody has a good write up with some pics for a diy change. I think you need a deep socket wrench to get to the sensor. If anybody changed it, post some comments. It seems to be a pretty common issue. I would change mine too, but I have no idea how to reach it. There must be some special trick to make it easier than just feeling for it and hoping the threads will seat properly when screwing it in.
