Oil change?
Old Dec 12, 2012 | 08:42 PM
nijoma's Avatar
Default Oil change?
I checked the oil today since it came up on my dash that is was time to change the oil. I used synthetic oil only in this truck, I am not due for another 1k, with synthetic I have been changing oil every 5k. I am 3-4 quarts low! Wtf, it is an Alpha but 5k isn't much for oil to be so low, no leaks and no smoke out tailpipes. Anyone had an H3 that went through oil like this or is this normal?
Old Dec 13, 2012 | 10:44 AM
egroegart's Avatar
That is not normal, and you are lucky that it is still running. There may be damage already done, but just hasn't shown up yet. We check our oil level once a week when we wash the Hummer. It is just a good practice to get into. As vehicles age and parts get more worn a lot of times they do go through some oil between oil changes but that is a huge amount and not safe for your vehicle to be running that low on oil. Always check your oil often. I set a calendar in my phone just in case I forget.
Old Dec 13, 2012 | 10:57 AM
Did you reset the OLMS the last time you changed your oil? If you did, then it is telling you that because it ran so low, time to change it.
Check your radiator fluid and trans for cross contamination.
Old Dec 13, 2012 | 11:03 AM
23111H3's Avatar
He HAD to mean 3/4 of a quart. Didn't he?
Old Dec 13, 2012 | 11:36 AM
ekeef's Avatar
I have an alpha and use to lose oil between changes like your talking. Two things why do you think you have lost 3 quarts? Are you going off the dots on the dip stick? I was told last oil change the stick only reads about a quart. With that being said I was loosing a little more than a quart. When I took it in to the dealer for my oil change i had them check for leaks. Turns out they replaced an oil seal groove that was melted to the axel. The normal oil leak signs were not there for me either.
Old Dec 13, 2012 | 10:38 PM
Oil seal groove that melted to your axle.......what? Did you pay for this or was it warranty?
Old Dec 14, 2012 | 10:04 AM
ekeef's Avatar
No it was a warranty repair...
Old Dec 17, 2012 | 08:35 AM
nijoma's Avatar
Default Turns out 3quarts low
Nothing wrong can be found, it is synthetic and about 6 k on truck since last change. Just have to be more careful to check oil and either add along the way or change the oils every 4-5k
Old Dec 17, 2012 | 06:49 PM
egroegart's Avatar
How much oil did it lose? was it 3 to 4 quarts? or did you mean 3/4 of one quart?
Old Dec 17, 2012 | 07:17 PM
nijoma's Avatar
Default No
I was down close to three
