Oil Capacity of H2 Transmission
Old Jan 16, 2011 | 10:39 AM
H2 Jay's Avatar
Default Oil Capacity of H2 Transmission
Iv searched online with no luck..Does anyone know the oil capacity of the H2 4 speed transmission.
Im ordering service items etc..but its hard to order oil when you dont know how much you need.
Any help is appreciated.
Old Jan 16, 2011 | 03:37 PM
Easy Ed's Avatar
Don't know if this will help but a 2003 service manual shows 5 quarts of Dexron III for pan removal and 11 quarts of same for an overhaul. But, it does also show 12.1 quarts dry ? Maybe that would be if the cooling lines were "dry" also ?
Ed
Old Jan 17, 2011 | 02:43 PM
H2 Jay's Avatar
Its kinda helpful..Still no real idea how much i would need for a service though.
Old Jan 17, 2011 | 04:58 PM
Easy Ed's Avatar
Old Jan 24, 2011 | 06:10 PM
medic/z28's Avatar
Usually 12 quarts means they're doing a flush and not recommended because 3 out 5 times it means you'll end up replacing the tranny. The 5 quarts means it's a pan filter drop and top off which is good enough and will do the job. I did it to my 02 and tranny temp drop significantly. Shifts harder and crisp when racing.
Old Feb 12, 2011 | 05:32 PM
AvrgJoe's Avatar
So I was thinking about chaning out the ATF to Amsoil ATF and putting on a larger tranny fluid oil cooler. So why would someone make a comment about the tranny going out if you change out the fluid completely, (pan and torque converter fluid change)?
Old Feb 12, 2011 | 05:36 PM
AvrgJoe's Avatar
Chaning = changing
Old Feb 13, 2011 | 10:51 AM
calif phil's Avatar
There is only two ways to service the trans, remove the pan and replace the filter, refill with 5-6 qts ATF. There is no way to drain the torque convertor. The other way is to take it to a shop and have them flush the fluid. I prefer the pan/filter method. Amsoil Syn ATF is good stuff. The pan gasket is reuseable so all you need is a quality trans filter from any GM dealer and some ATF.
drtom
Jan 17, 2011 09:23 PM
EastTnMike
Aug 18, 2010 11:19 AM
hummer07
Nov 18, 2008 10:46 AM
mcne2026
Dec 20, 2006 10:37 AM
ty_r1
Oct 25, 2005 03:47 PM
