Off Road Lights Install HELP! please
Old Apr 3, 2011 | 03:00 PM
rwheeler54's Avatar
Default Off Road Lights Install HELP! please
I have the lights on, switches in place, now to run the wires....
WHERE do you run the wires? I cant find any place to get the wires outside of the cab, I even tried drilling a hole, but was unsuccessful..how did you guys run your wires...
Old Apr 4, 2011 | 09:26 AM
Stonewall88's Avatar
I ran my wires just above and to the left of the brake pedal. There is a small area that is covered by insulation. I pulled that little square off and drilled a hole just large enough to to fit was i needed to through it. then wrapped the wire with electrical tape in the area where the wire would rub the firewall so it would not rub the wire. Thats about it. Pretty easy just takes a little time.
Old Apr 4, 2011 | 08:03 PM
CARdiac's Avatar
Did you caulk the hole to seal it?
Old Apr 4, 2011 | 10:22 PM
drtom's Avatar
Banned
do a search. there are 6 blunt cut wires near your left foot so says other posts. they go out behind battery for hooking up lights. u dont need holes.
IF u drill holes,drill big enuf for more wires later!.a 1/2 inch is good. use a rubber grommet to insulate,then fill with sealler,caulk u can pull later when u need to run more!
rojah247
Sep 9, 2018 09:03 PM
bobopotato
27
Jul 30, 2011 09:09 AM
Theuofmiami
Aug 30, 2010 08:13 PM
THE BEAST
Jan 2, 2010 10:09 AM
CruisinCarAudio
May 25, 2006 04:14 AM
