OEM Off Road Light Switch Connection
Old Dec 5, 2017 | 08:07 PM
Ewmoore99's Avatar
Default OEM Off Road Light Switch Connection
Hello all. I have LEDs on all sides of my rig and have them all connected to my Feniex 4200 Mini controller that I mounted just in front of the gear shifter over the little tray there. I was able to run all my wires using 1 cord I found at Lowes and ran it trough the door jam so I didn't have to drill into my firewall. Now I find myself needing 2 more switches but am hesitant to run any more wires in the door jam and creating a WT look. I was doing research and noticed the OEM switches use a wiring harness. Does anyone know where they plug into and if it is already ran through the fire wall. I know GM ran wires for a trailer brake and just taped them under the dash and I was wondering if they maybe did the same thing here. Thanks guys!
Will Post Pictures Soon!
Old Dec 6, 2017 | 10:07 AM
These are the wires for the AUX lighting that are unused. Look under the driver side dash. They are the same under hood.
ORANGE, BROWN & BLACK & WHITE
Old Dec 7, 2017 | 09:07 AM
Ewmoore99's Avatar
This is exactly what I needed! I really appreciate it!
Old Dec 8, 2017 | 09:29 AM
speedy2000's Avatar
Noob question, are these wires just a 12V power source and ground? If so which colors operate what? And i would assume a fuse is needed somewhere as when I opened my fuse box under the hood the AUX lighting appears to be missing? Size of fuse needed?
Old Dec 8, 2017 | 08:41 PM
They dead end on both sides of the firewall.
Old Dec 15, 2017 | 09:00 AM
Ewmoore99's Avatar
I would suggest using these as the trigger wire for a relay if you're going to run anything substantial. You'd want to run a fused hot line from the battery to the relay so if anything happens you have a controlled weak link.
Old Dec 15, 2017 | 10:08 AM
speedy2000's Avatar
Thanks, Ill just run a whole new setup into the truck from the battery and add an Aux lighting box. Im installing one light bar now and plan to add a few more later. Would rather do it right now than splice into wires.
gregaac
Aug 17, 2021 03:20 PM
fyr145
18
Jun 11, 2020 08:28 AM
08xcab
Apr 3, 2011 07:34 AM
dinov
Mar 2, 2010 11:52 PM
augustin01
Jun 18, 2008 06:07 PM
