Odd front vehicle movement while driving
Old Jan 16, 2015 | 09:00 AM
Man1nboat's Avatar
Default Odd front vehicle movement while driving
Good morning! I ran into (at least I believe so) my first mechanical problem. I have a question for the group. When driving my H2 at speeds above ~40, I feel the front end tracking funny. It will be fine then periodically feel like it wants to track slightly right an left. Could this be the stabilizer bushings, hub, something in the front end linkage i.e. pitman arm? I appreciate all you do!
Richard
Old Jan 16, 2015 | 12:59 PM
madmayo's Avatar
How old are your tires? Are they wearing even? Any scalloping? Shifted belts?
My last set were the oem BFG at's. They had all the symptoms mentioned above. Night and day difference when they were replaced. Could also have tires out of balance as well.
Also could be any of the things you mentioned including tie rods.
Get someone in the truck. Have them start the truck. Leave it in park. Chock the rear wheels. One block in front and one behind the tire.
Now you lie underneath the front and watch for any slop or play in all those parts you mentione while they saw the wheel side to side. If there is they need to be replaced.
You can also jack each front wheel up separately. Put a jackstand under the frame as well for a second safety device. Wheels chocked.
Grab the tire from top and bottom and see if there is any play there. If so you've got a bad ball joint.
Old Jan 17, 2015 | 12:42 AM
Man1nboat's Avatar
I will check this and reply. Thanks @madmayo!
Old Jan 17, 2015 | 11:47 AM
Throttle Fever's Avatar
Default Sounds like wheel bearings
Check your wheel bearings, as stated in previous post jack it up and give each wheel a shake, most likely the wheel bearing assembly.
Old Jan 17, 2015 | 05:48 PM
Man1nboat's Avatar
Well it appears that both hub bearings are shot! I jacked each wheel up and there is extreme slop. I moved the wheel and the upper and lower ball joints weren't moving so it loos like tomorrow I will be changing not hubs.
Old Jan 18, 2015 | 10:38 AM
Thanks for the update, sorry for the bad new there. Hubs are not that big of a job, just have yourself a long breaker bar to break loose the bolts. She will drive like new when you get that done....
Old Jan 18, 2015 | 04:14 PM
Man1nboat's Avatar
Update: Both of my hugs were completely shot and I replaced them today. Took 4 hours because the bolts were really seized. All's good!
Old Jan 19, 2015 | 02:56 PM
nlhummer's Avatar
These thing eat hubs like there is no tomorrow
Bill2beach
Jul 20, 2015 09:03 PM
hummerhank
Jan 2, 2011 07:56 PM
roycel
Aug 3, 2010 06:26 PM
Dan1127
May 3, 2010 02:52 PM
wkech2
Feb 28, 2008 10:49 AM
