Noise in front end
Old Dec 19, 2015 | 07:56 AM
thorg113's Avatar
Default Noise in front end
When I'm driving down the road I hear a fast passed clicking noise coming from the front end and when I'm stopped and let off the brake so the tranny moves me without any throttle I can hear a cluncking noise coming from the front end. I changed the half shaft on both sides I'm not sure what else the noise could be coming from. Any ideas?
Old Dec 19, 2015 | 12:21 PM
happythree's Avatar
so did the noise start just when you changed the shafts, like the first time you drove it??
i figure you go to the last place work was done for a new problem.
Old Dec 19, 2015 | 12:25 PM
thorg113's Avatar
The noise was there before so I thought it was the half shafts so I changed them and the noise is still there
Old Dec 19, 2015 | 09:42 PM
skeeter's Avatar
check the front wheel bearing assembly
Old Dec 19, 2015 | 09:43 PM
thorg113's Avatar
Would a wheel bearing make a cluncking noise though? I've never had a wheel bearing go badown before so I'm not sure how to check it or listen for one
Old Dec 20, 2015 | 03:05 PM
82Toy's Avatar
Depends on how bad wheel bearing are, however if cv shafts were changed, the mech would of noticed the worn bearings.
Old Dec 20, 2015 | 03:07 PM
thorg113's Avatar
I changed them myself so I wouldn't of been able to notice that I guess I just jack it up and see if the tire will wiggle. I did notice though that I'm dripping power steering fluid by that long shaft going to the tie rods
Old Dec 22, 2015 | 08:39 AM
jbwk254's Avatar
clunking from a stop sounds like the front diff bushing is bad
Old Dec 23, 2015 | 06:12 AM
Sounds like the lower differential bushing is shot.
Old Dec 23, 2015 | 06:48 PM
thorg113's Avatar
Would that cause it to click really fast when giving it throttle. Could it also be a bad bearing in the axle where the cv joint slides into the differential
