No power to passenger door
Old Aug 10, 2011 | 10:40 AM
H2SS's Avatar
Default No power to passenger door
I can't figure out how I lost power to the passenger door (windows, lock, mirror). The factory alarm system is also inop. This happened after I did an aftermaket stereo swap. I had to replace my Pioneer x930bt with a new one due to the remote wire shorting somehow. Anyway, in the middle of the swap I tried to start the H2 with no stereo in. I forget what my reasoning for this was. The starter was turning over however the engine would not start. After I installed the new stereo the truck turned over fine but now no alarm or power to the passendger door.
I've read in a few places to disconnect both battery leads then connect them to each other to reset, that did not work. All fuses are good to go. This article was no help either.
Is it possible that I screwed something up in the center console where the stereo, onstar and hvac are mounted?
Old Aug 10, 2011 | 06:56 PM
PanicAttack's Avatar
Hi. This happened to my '03 last year. The dealer told me that I had to get the passenger door module replaced ($$$) and reprogrammed. The total cost was going to be $600+.
My passenger door is completely dead (the power seat still works) and my remote key fob won't work.
There is a technical bulletin out on this issue and my truck has all the symptoms. I'm saving for bigger tires so the power windows can wait!!
Kelly
Old Aug 12, 2011 | 01:38 PM
H2SS's Avatar
Thanks Kelly. Now to find the part number.
Old Aug 16, 2011 | 09:19 AM
H2SS's Avatar
Remote Keyless Entry (RKE) System Inoperative (Reprogram Passenger Door Module) #03-08-52-001C - (Mar 17, 2003)
2003 Cadillac Escalade, Escalade ESV, Escalade EXT
2003 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003 GMC Sierra, Yukon, Yukon XL
2003 HUMMER H2
From Start of Production (SOP) through December, 2002 for the 2003 Model Year
This bulletin is being revised to provide the latest service information. Please discard Corporate Bulletin Number 03-08-52-001B (Section 08 -- Body and Accessories).
Condition
Some customers may comment on any of the following conditions:
* The RKE key fob does not function.
* The RKE has a very limited range.
* The passenger door will not unlock from the passengers or drivers door switches.
* The passenger door window is inoperative.
Correction
Important
For clarification purposes, the following information is provided. The components involved in this bulletin are known by various names. The Service Information Document ID #849813 refers to the component as the Door Lock and Side Window Switch. General Motors Service Parts refers to the components as SWITCH DR LK & SI WDO. Within this component is a micro processor that is referred to as the Passenger Door Module (PDM). Techline equipment refers to the component as the PDM Passenger Door Module. This bulletin addresses issues with the software of the microprocessor in the Passenger Door Module (PDM).
Perform the following procedure step by step (do not skip a step) to determine the proper course of action.
Important
Verify the software version in your Tech 2. If the software is not 23.001 or newer, your Tech 2 software needs to be updated.
1. Determine the production date of the vehicle by viewing the certification label on the driver's door.
* If the vehicle's month of production is PRIOR to 01/03, go to Step 2.
* If the vehicle's month of production is 01/03, THIS BULLETIN DOES NOT APPLY. Refer to Customer Satisfaction Program bulletin 03011, published March 2003.
* If the vehicles month of production is 02/03 or newer, this bulletin does not apply. Refer to published Service Information for the symptom experienced by the customer.
2. Use the Tech 2 to determine the PDM operational software release number.
* With the Tech 2 installed and powered up, verify the software version. If the software is not 23.001 or newer, your Tech 2 software needs to be updated.
* Press Enter.
* Select: Diagnostics.
* Select model year: 2003.
* Select: Light truck.
* Select : Body.
* Select the proper Product line.
* Select the proper HVAC Type.
* Select the proper Radio System type.
* Select: Passenger Door Module.
* Select: Data display.
* Select: Module 1 information.
o If a number is displayed following "Operational S/W Part Number" , continue with the next bullet.
o If an (*) is displayed following "Operational S/W Part Number" , go to Step #3 below.
* If the "Operational S/W Part Number" is 15181562, 15186199 or 15186460, exit out of this bulletin procedure. Refer to Service Information to diagnose the condition reported by the customer (the vehicle has the most current software as of the date of this bulletin).
* Exit to the Main Menu.
* Perform normal SPS reprogramming of the Passenger Door Module.
* Go to Step 4.
3. If an (*) is displayed following "Operational S/W Part Number" , return to the screen which will allow you to select the Passenger Door Module by pressing Exit (3) times.
* Select: Special Functions.
* Select: Refresh.
* Follow all on-screen instructions.
* When the Tech 2 displays "Refresh Procedure Successful", Exit to the Main Menu.
* Go to Step 4.
4. Return the vehicle to the customer.
Old Aug 16, 2011 | 09:31 AM
H2SS's Avatar
Model Year(s) - 2004
Vehicle Line(s) / Condition - Tahoe, Suburban, Silverado, Yukon, Yukon XL, Sierra, Escalade, Escalade EXT, Escalade ESV, H2 - Passenger Door Module and RKE Inoperative
Do This - Re-flash the passenger door module. Labor Operation: N9505
Don't Do This - Don't replace the passenger door module. Labor Operations: N2116, N2114
Reference Information/Bulletin - 04-08-52-005 (June 2004)
Old Aug 16, 2011 | 09:42 AM
H2SS's Avatar
Keyless entry: The remote keyless system quits working and there was a campaign to reprogram the electronic module inside the passenger door and this fix will be made at no charge regardless of time or mileage. (2003)
http://ww2.justanswer.com/uploads/Bl...4405_03011.pdf
jm4490
44
Aug 12, 2017 12:52 PM
remmy
Jun 7, 2014 08:06 PM
pitsingerk
Jan 17, 2012 09:57 AM
steveng
Dec 22, 2010 09:43 PM
H3gal
Jul 24, 2006 01:26 PM
