No cost,rainproof hood vent
Old Aug 19, 2012 | 07:11 PM
happythree's Avatar
Default No cost,rainproof hood vent
I've read a lot recently about hood vents and the cost,installation,and possible water hazards.
I remembered how kids used to jack up the back of their hood to let air escape. When i checked my h3 for the bolts I saw 4 bolts,easy to remove and add spacers,1/2 inch or more. It might take longer bolts.
Then i looked at the rubber seal and see that it is easily removed.
So the no cost,no work approach is the rubber seal,the bolts could be extended for more vent space. Both can be done at no cost and 100% restorable for winter,or if you change your mind,or see that its not needed.
Is anyone recording temps over the 195 thermo rating? If so you could pull the seal and check it out,no charge.
the 4 hinge bolts and the rear rubber hood seal are the items
ArizonaFeeds
Sep 16, 2012 02:21 PM
jeffwhiteis
Aug 16, 2011 08:59 AM
jeffwhiteis
Jul 24, 2011 06:36 AM
jeffwhiteis
Jul 23, 2011 07:05 AM
Cheesehead H3
Mar 9, 2007 10:33 PM
