Newb Questions
Old Nov 9, 2010 | 08:56 PM
CARdiac's Avatar
Default Newb Questions
OK, I have a couple of Newb questions. I did a couple of searches but can't find the answers.
What is the cylindrical gauge on the side of the air filter?
Oil life count down... how do I find that? My dash has the odo but it cycles between the trip and odo but not oil life. Is it an option or standard?
The dash lights do not dim, only the nav dims with the switch, is this normal?
Is there a good service manual out there for a 2008 H3 Alpha?
What are some good vendors for parts and accessories?
I had an old GM, there was a way to crosswire the relay where the fog lights stayed on with the brights, is that possible on the H3?
Thanks for your help
Joel
Old Nov 10, 2010 | 12:14 AM
drtom's Avatar
Banned
Default spend some reading earlier posts, search,
a company,HELM, provides manuals, apx,$160.
most q have been answered b4
Old Nov 10, 2010 | 05:45 AM
Broken Halo's Avatar
Attachment 2413
Joel
The oil life doesn't have a 'count down', it just comes on with a 'change oil soon' warning.
The cylindrical gauge tells you the condition of your air filter. As the filter gets dirty, and restricts air flow, it creates a suction on the gauge moving the indicator from green (good) to red (dirty).
See attached diagram for fogs + brights. Enjoy your Alpha!
[IMG]file:///C:/DOCUME%7E1/Randy/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
Old Nov 10, 2010 | 02:25 PM
CARdiac's Avatar
Thanks, on the crosswire- am I just connecting those terminals or do I need to cut the terminal and wire it to the headlight relay?
Old Nov 10, 2010 | 02:51 PM
bflank's Avatar
Actually the Oil Life does have a percent remaining but there is no way built in to read that out. OnStar reads that on the monthly diagnostic report & emails it to you. You can also read it using a ScanGuage II, which I have in my H3 & highly recommend.
Old Nov 10, 2010 | 03:25 PM
No cutting necessary. Pull the 2 relays, stick the diode ends in the #86 slots, and pop the relays back in place. Be sure the silver band on the diode faces the fog light relay as shown in the diagram.
Old Dec 15, 2010 | 08:42 PM
CARdiac's Avatar
I finally got around to putting the diode in. The fogs shut off and come back on after a 2 second delay when switching from highs to low... is that normal?
Old Dec 15, 2010 | 10:18 PM
drtom's Avatar
Banned
yeah mine blinks, a little confusing for oncoming i spose!
Old Dec 15, 2010 | 11:16 PM
NIUPonyBoy's Avatar
Itzz t'ha pole'ce!
Old Dec 16, 2010 | 05:02 AM
Yep....normal.....mine do the same thing.
Dabber
Apr 16, 2011 07:07 PM
julygold
Jul 24, 2008 12:37 PM
Hummer Guy
24
Feb 12, 2007 02:01 AM
wz56km
Dec 19, 2006 01:19 PM
Jake
Jul 10, 2006 11:59 PM
