New wheels
Old Apr 5, 2017 | 12:01 PM
FatJay's Avatar
Default New wheels
I'm looking at a set of wheels for my h2. The thing I'm concerned about is offset, I have no idea what it is or how it works. There's a sale at my local pepboys buy 3 get 1 free. My factory wheel chrome is pitting, so a new set of wheels for $400 is rather appealing.
This is the wheel in question: https://www.pepboys.com/product/deta...5206.0L/63689/
Any input on how it will fit would be appreciated.
Old Apr 5, 2017 | 12:47 PM
My guess is those will work perfectly fine.
There are two primary specs. Offset and backspacing. Backspacing is the distance from the flat of the mounting plate to the outer edge of the wheel. Offset is the distance from the flat of the mounting plate to the center of the wheel width.
So I'm figuring on mine, add the .1 offset to the 4.89 backspacing and you have nearly right at the 0 offset, 5 backspacing on those.
I just checked the specs on the Rockstar XD775 wheels that came on mine (I'm selling them, putting a set of stock chrome wheels on). Anyways the specs on the Rockstar wheels on mine
17" x 8" wheels, 8x165.1 bolt pattern, offset 10, 4.89 backspacing, 130.81 center bore.
Old Apr 5, 2017 | 02:20 PM
FatJay's Avatar
Unless i'm missing it, I'm not seeing the bckspacing stats on the wheel. I can't find any other info on the wheel, either. It's 17x9, so an inch wider right?
I guess I could always return them if it doesn't work out.
Old Apr 5, 2017 | 04:53 PM
Its on the pepboys page - bottom of the main description. 8x6.5 (8x165.1 bolt pattern) 5.00 back space. The specs tab shows the offset as 0.
Old Apr 6, 2017 | 09:58 AM
FatJay's Avatar
Sorry for my ignorance. Does that mean it'll be about the same as stock? the 9" wide, that's a bit wider right?
Old Apr 6, 2017 | 01:18 PM
The rims themselves are .5" wider than stock. The factory rims are 17x8.5. Thats not enough that it will make any real difference. The sidewalls of your tires will be ever so slightly "flatter" since at the rim edge they will be .25" further out than before.
I cannot imagine that will really matter...
Old Apr 6, 2017 | 06:54 PM
FatJay's Avatar
Just clicked buy. My chrome wheels are pitting/flaking badly, and it's an eye sore every time I see them. To get them fixed would be as much if not more than these wheels at buy3 get one free. And I can return them if I don't like them.
BMoney5327
May 7, 2012 07:36 AM
sdot425
Sep 14, 2011 09:04 PM
hilljob26
Sep 26, 2007 05:00 PM
diamondh2
Jan 11, 2007 11:10 PM
thaidoggs
Dec 28, 2006 06:26 AM
