new terminal,best way
Old Mar 14, 2016 | 05:27 PM
happythree's Avatar
Default new terminal,best way
just found pix. this preserves the factory crimp,none better.(if i had to cut the cable id solder a ring terminal on it to connect to brass,better!)
the old term is flattened and cut so a hole can be drilled for bolt/nut.in this pix it mounts on bottom, absolutly solid.
brass came from napa/? toss the cable clamp,not used. 2nd bolt for accs or dual batt setup.
Old Mar 17, 2016 | 05:58 PM
rascole's Avatar
Put some solder or liquid tape over those exposed wire ends. Water WILL creep in and corrosion WILL begin.
Old Mar 17, 2016 | 06:28 PM
happythree's Avatar
thats the LAST of my worries! that crimp is tighter than you can get with any of the pretty connectors ive seen.it may be considered gas tight.
probably every car leaving the factories are like that, millions. its the clamp that goes bad.
actually there are thousands of connections crimped like that on all the connectors in any vehicle,none sealed.
126Andy
Mar 7, 2016 08:54 AM
Hunner
Oct 19, 2012 06:54 AM
drtom
Apr 21, 2012 02:49 PM
drtom
Apr 20, 2012 10:50 PM
HummerGuy
Nov 12, 2007 12:54 PM
