Need some help with Wheel nuts
Old Oct 25, 2010 | 03:42 PM
bosch's Avatar
one way to get them off if there not too tight would be to use a mig welder and weld an extention onto the end of the nut ,then try to remove it , i have had to torch some off and use a air hammer before on trucks that people have lost there sockets .good luck mike
Old Oct 25, 2010 | 07:50 PM
mikeyd's Avatar
i've had good luck with using a 12 point that comes close and a hammer , ive also ground out a socket to round and used a mig to weld in splines inside (built up with just weld).
the other Mike
Old Oct 25, 2010 | 07:57 PM
HarryBoy's Avatar
Thanks guys for the advice, i have found a site that does 7 point lug nut key. so i will get a set of them shipped from the states as they arnt availible in the UK. Hopefully fingers crossed they will work! Otherwise it will have to be a get off however I can by the look of things.
Old Oct 26, 2010 | 04:41 AM
bosch's Avatar
you know right after you get them off you will find the correct socket , like under a seat or something.good luck.mike
Old Oct 26, 2010 | 07:05 AM
Pauldy's Avatar
Found the company that makes them and they are out of business. So it looks like you have your work cut out for you.
http://www.mc2ing.com/
Old Oct 26, 2010 | 07:13 AM
HarryBoy's Avatar
thanks for that even if was a bit if bad news!
looks like ill just have to get heavy with them!
thanks for all your help guys.
Old Oct 26, 2010 | 08:24 AM
calif phil's Avatar
Snap-On sells some special sockets for removing locking lug nuts. I have a set. You might try some auto repair shops around you to see if they might have the socket they could rent you. Maybe call a Snap-On dealer if you have them and ask him if he has sold any and maybe he could tell you what shop has them.
Old Oct 29, 2010 | 07:22 PM
Bimmer9938's Avatar
Those are spline drive lugs (aka: tuner), you should be able to get a cog from anyplace here in the states that sells spline drive lug nuts.
jdrew
21
Jun 6, 2008 11:58 PM
Dennis
28
Jul 17, 2007 10:20 PM
blackstangs281
Mar 20, 2007 11:15 PM
whododat
Dec 3, 2006 10:37 PM
skeeet
May 5, 2006 10:33 AM
