Need more heat
Old Jan 28, 2008 | 10:42 PM
Koboss's Avatar
Default Need more heat
Does anyone know how to get more heat out of my truck, 2000 H1 Hardtop.Right now it's-47 below. And how bright are the black diamond headlights on E-bay? only $8.99
Koboss
Old Jan 28, 2008 | 10:48 PM
Injunfarian's Avatar
Default RE: Need more heat
For more heat... the H1 doesnt really have a good heater core... only thing you can do is make sure your coolant is topped off and when at redlights i usually idle around 1600-2000...
Next year there may be an accessory to help with the heat... I am currently working on some templates that hopefully will keep our engine temp at 200 during the colder winters and it will be a bolt on accessory no mods at all and can easily be taken off for the warmer months or "opened up" for the warmer days/high way travel in the winter months....
but sad to say it wont be out till next year
Old Jan 28, 2008 | 11:11 PM
Gunner_45's Avatar
Where exactly in Antarctica are you located?
Old Jan 28, 2008 | 11:16 PM
-47? I don't think any auto heater is going to make much of a dent in that. Time to throw another log on the fire and pour yourselfanother scotch.
Old Jan 29, 2008 | 12:07 AM
Koboss's Avatar
I'm up in Alberta, Canada. And the Scotch up here is getting very expensive. The wind chill is -56. I have the motor tarped up it's running around 220 degrees, im getting decent heat in the back, but not much up front.
Koboss
Old Jan 29, 2008 | 12:12 AM
The fans just don't push the air very hard so it isn't going to penetrate very deep into the truck. You also have lots of glass.
Old Jan 29, 2008 | 12:17 AM
Gunner_45's Avatar
I just can not imagine temps in those ranges....Great Googley Moogley.
Old Jan 29, 2008 | 08:29 AM
hmcoleap's Avatar
If you are getting good heat in the rear but not in the front, I would suspect something isn't working properly; you may want to have it checked out to make sure that there isn't a gate/flap stuck partway open, a loose vacuum hose connection, or a problem with any of your duct/connections.
There are also heat shields in the area below the transmission shifter, e-brake and t-case lever -- I found that with those removed, more engine/exhaust heat comes up into the cab in that area.
You can also buy a small 12v heater/blower and aim it directly at yourself (or a passenger) -- it doesn't have much of a range, but I got one and my wife loved having another area of warm air to put her hands in front of, etc.
Old Jan 29, 2008 | 03:56 PM
xzachx2112's Avatar
hell if its 56 below start a campfire in your hummer!
Kreke
Oct 10, 2008 06:07 PM
OnAll4s
May 6, 2008 08:26 AM
HummerGuy
Feb 14, 2008 12:57 PM
vilim12
30
Jan 8, 2008 01:06 PM
vilim12
Jan 6, 2008 07:51 PM
