Need Info on back door jack.
Old Mar 25, 2010 | 06:52 PM
Tonyg41's Avatar
Default Need Info on back door jack.
So as some of you know/have seen, I had a sub placed in the back door of my h3 sadly the life of my sub box ended the other day. It happened when a 30lb box hit the side of it ripping out the sub and pulling the enclosure from the door. If I would have gone with a shallow mount sub this would have not done any damage. That is a warning to those considering putting a sub in the back door that isn't flush in the door. I am have a box made that can be removed when I have to transport things so this wont happen again. Now I need to restore the back door to its original condition. The audio shop I had the enclosure made by cut the plastic tabs on the plastic bottom trim piece and also trimmed some metal off the inside of door to fit the box. I cant put the little plastic door on until I buy a new piece. My problem is I cant remember how the tire jack screws into the back door and I am requesting if someone can take pictures of how this is supposed to be or explain how it mounts with the big screw so I know whether or not if they cut off the part needed to mount this jack or I am just missing the spot where it mounts. Thank you.
Old Mar 25, 2010 | 08:21 PM
DAGKANA's Avatar
Old Mar 25, 2010 | 11:37 PM
Tonyg41's Avatar
Originally Posted by DAGKANA
A course I already looked at those but, my problem is I dont see what that bolt in going into besides the the jack itself. Im trying to understand if the guys cut a bracket or something out of the door frame and that is why I cant mount it.
Old Mar 27, 2010 | 05:05 AM
Tonyg41's Avatar
I figured out the problem, there is a retainer nut that goes behind the bolt that goes through the jack which the guys were able to lose it.
logicbyondreason
May 16, 2012 04:19 PM
FALSE FACE
Jun 13, 2010 09:23 PM
lucky19942001
Apr 3, 2009 06:22 AM
h3newguy
Sep 11, 2007 08:24 PM
gangstagirl
33
Feb 9, 2007 04:44 PM
