need info
Old Nov 21, 2013 | 01:43 PM
dougie's Avatar
Default need info
my 2003 Hummer H2 is acting weird with the electrics. The dashboard bulbs stop working for a few days then start again and this cycle goes on. A few nights ago the dashboard went completely dark, even the dials not working so I don't know how much gas is in the tank.Even when I start the car nothing shows on the dash. Ihave checked the fuses and cannot find any broken fue. Has anyone any idea what could be wrong?
Old Nov 22, 2013 | 11:14 AM
fyr145's Avatar
Being that you have power to start the motor rules out any sort of main power issue. Since its only the instrument panel (IP) that is malfunctioning and no other systems, then I would suspect a faulty connection somewhere in the IP. I would start by removing the IP and look at the circuit board and look for any unusual burn marks that might indicate some kind of intermittent short. Removal of the IP is very easy, watch the video tutorial below.
Also, when you say you checked the fuses, did you just visually look at them or did you actually place each one onto a meter and check for continuity??
Old Nov 23, 2013 | 09:34 AM
yoymon's Avatar
ive read that instrument panel is a common problem with our h2's, if you look on ebay theres a place that sells new and refurbished ones, if you decide you need to replace it
Old Nov 23, 2013 | 09:38 AM
yoymon's Avatar
DirtNMyTeeth
Oct 15, 2009 06:22 PM
Rob4092xx
Aug 7, 2009 09:54 PM
importkiller
30
Mar 26, 2008 01:39 AM
h3newguy
Sep 11, 2007 08:24 PM
gangstagirl
33
Feb 9, 2007 04:44 PM
