Need help
Old Apr 9, 2017 | 03:42 PM
dljenson's Avatar
Default Need help
My 2006 H3 just started acting up, turn key idles for 5 seconds then shuts down. Can't get it to keep running. Sometimes it spits and sputters before shutting off. It kind of acts like it isn't getting fuel. Anybody got any ideas on what I should do?
Old Apr 10, 2017 | 08:30 AM
Is it showing any codes or a check engine light?
Old Apr 10, 2017 | 09:33 AM
dljenson's Avatar
Thanks for the reply, nope not showing and messages , I don't have a code reader yet.
Old Apr 12, 2017 | 10:49 AM
I have two ideas: 1) Do NOT post in the H3 FAQ section, where it says in a sticky thread at the top https://www.hummerforums.com/forum/h...section-19461/
2) When was the last time you fueled it? Fuel gauges/sensors die, when they do you do not know what if anything is in the tank. Easy stuff first. Add a couple gallons with a can, then see what happens.
Old Apr 12, 2017 | 11:30 AM
dljenson's Avatar
I filled the tank the day before it started to act up.
Old Apr 12, 2017 | 12:47 PM
Happy Hummer's Avatar
Bad fuel?
PassLock?
Old Apr 12, 2017 | 01:05 PM
dljenson's Avatar
Same place I've been getting gas for the last few months. What is passlock? I got a new code reader waiting for me at home, so I'll be able to check codes then.
Old Apr 12, 2017 | 03:33 PM
Search GM Passlock. Do you have a flashing security light (the little lock symbol) lit or flashing?
You may have to confirm fuel pressure with a gauge at the fuel rail
When you turn on the key, can you hear the fuel pump run to build pressure?
Old Apr 13, 2017 | 08:39 AM
dljenson's Avatar
Hooked up code reader, no codes found. I tried the 10 minutes key on and 10seconds key off did this three times still nothing seems to work. I've wanted a Hummer all my life, (61) now when I got one the darn thing will not run. I have no idea what to do except for draining the tank and adding fresh gas.
Old Apr 13, 2017 | 10:43 AM
It could be something as simple as a frayed wire harness bad connection at the fuel pump. Crawl under there and scope it out.
Have someone else turn the key and listen for the fuel pump.
