nav unit antenna
Old Jan 21, 2007 | 08:00 PM
CCMDoc's Avatar
Default nav unit antenna
Anyone have a factory installed nav unit? If so, where does the antenna mount braket attach(metal braket with a couple of holes in it and abouta foot of antanna wire from the back of the unit to this mounting plate)?
Old Jan 22, 2007 | 06:54 AM
Default RE: nav unit antenna
ORIGINAL: CCMDoc
I MAY be wrong, but I believe on the wife's Escalade, itwent UNDER the top of the dash??
Old Jan 22, 2007 | 05:14 PM
CCMDoc's Avatar
Thanks. When I pull the radio, Ill look for a place up under the dash.
Paul
Old Jan 22, 2007 | 09:25 PM
H3X442's Avatar
According the service manual it is located behind the left center a/c duct. The manual calls for the dash to come out to get to it. The next time we have a dash out to replace a heater core I need to take a look at where it is. If I get lucky it will be one with navigation. Steve
Old Jan 22, 2007 | 09:50 PM
CCMDoc's Avatar
ORIGINAL: H3X442
Thanks Steve.
BTW, what is the P/N for the service manual? I have them for every other car I have owned and they are invaluable as you already know.
Old Jan 23, 2007 | 08:46 AM
H3X442's Avatar
We get all our information web based so no paper. If you go to helminc.com they may have paper/cd manuals. Steve
Old Feb 4, 2007 | 08:23 PM
H3X442's Avatar
I got a look at a factory nav unit and where the gps ant. goes. You do not need to remove the dash *(like the sevice manual states). It is located at the firewall behind the radio near the left center a/c duct. There are 2 mounting tabs/towers that you screw it to. They are a little tricky but see no problem installing it. Steve
Old Feb 4, 2007 | 08:36 PM
CCMDoc's Avatar
ORIGINAL: H3X442
Thanks again Steve.
Do you know which amplifier goes with the oem nav unit vs what goes with the oem single CD stereo?
My On-Star and Nav volume is almost too low to hear.Nothing I do makes it loud enough.
I suspect a different amp is used witht he nav unit vs the base OnStar/XM/Single CD unit I have.
Paul
jvorpahl
Sep 13, 2020 09:15 PM
Tram
Jul 21, 2011 12:08 PM
ssanders
Dec 10, 2007 07:56 PM
wellperfused
Nov 9, 2007 02:17 PM
tarheel_34
Mar 18, 2007 03:29 PM
