My 2007 Hummer is a blood hound
Old Mar 1, 2013 | 03:22 AM
ultraclassic01's Avatar
Thumbs up
"Throttle Body". That is a vacuum source for the EVAP, just follow the black hose connected to the front top to where it goes around and under the intake manifold to the control valve, from there down under the truck to the fuel tank. If it come loose, gets cracked, or chafes a pin hole, that is your problem.
They have been known to get dry and crack, possibly just be a tad loose where connected to the TB & or control valve.
#1,12, 5 & 14
Ask and you shall receive! Thanks Doc for the diagrams. I will print them out and start checking connections and hoses that you indicated.
Old Mar 2, 2013 | 06:11 PM
iubhounds's Avatar
Originally Posted by TAINTER
I have also had the Large Evap code and the Canister replaced on another due to too much mud and filth-flarn in it.
where is this Canister located that you speak of?
Old Mar 3, 2013 | 02:36 PM
#17 on the illustration posted above. Rear end up behind rear axle.. 1 bolt, 1 connector, & 3 lines connected to it (1 from the vent valve)
Old Mar 3, 2013 | 11:46 PM
The evap canister is directly above and to the rear of the center of the rear axle. Mine had tons of mud and filth plugging the breather thingy. I do wash the underside after wheeling but never paid attention to the canister. Now I spray that off also.
dilo2001gt
May 24, 2012 10:43 AM
dilo2001gt
Sep 12, 2006 10:57 PM
hummerific
Jun 29, 2006 04:06 PM
dilo2001gt
17
Apr 3, 2006 03:06 PM
