my 1995 H1 issues
Old Feb 17, 2013 | 10:30 PM
browny's Avatar
Default my 1995 H1 issues
Hello everyone,
it seems that i have some issues in my H1 (6.5 non turbo) , here is the story :
- i drove it yesterday around 200 miles and i noticed that the speed goin down badly in the heights it jumps from 70 to 50 and i think that the transmission doesn't shift back from 4th to 3rd gear, any ideas ?
- when i reached home i started it again after an hour, i didnt hear the fuel pump sound and the wait light keep flashing but, the engine starts. when i drove it like 100 feet then suddenly the engine turned off ??
Thx,
Old Feb 18, 2013 | 08:24 AM
Sounds like a fuel delivery problem. When my 94 is warm I don't get the wait light. Lots of things you can check but first thing I would do is take the fuel filter out and inspect it. You can see if the filter needs to be replaced while checking to see if the filter canister is full. If it isn't your lift pump isn't working. That could be anything from a bad pump, to electrical connections, etc.
Old Feb 18, 2013 | 10:37 AM
browny's Avatar
i'll check the fuel system today and i'll feed you back
Thx
Old Feb 18, 2013 | 07:23 PM
browny's Avatar
i checked the filter and its clean, where i can find the fuel pump fuse or relay .
Old Feb 18, 2013 | 09:15 PM
Was the canister full of diesel?
Old Feb 18, 2013 | 09:24 PM
Lift Pump Testing Procedure
This is from the Hummer Knowledge Base at Humvee.net
Old Feb 18, 2013 | 09:37 PM
browny's Avatar
the canister is not full, and i removed the lift pump and i tested it with 12v and i didnt hear it running.
Old Feb 19, 2013 | 12:55 PM
Seems like you found the problem. At least they are pretty cheap and easy to replace.
Old Feb 21, 2013 | 10:41 AM
browny's Avatar
i want to know the fuel movement sequence
fuel tank to lift pump to fuel filter to >> ?
Old Feb 23, 2013 | 02:08 AM
browny's Avatar
i just installed the pump and new relay and its running perfect now
3hummers ,,, thank you a lot
