mirror issues...fuse?
Old May 9, 2011 | 12:00 PM
Highlander_H3's Avatar
Default mirror issues...fuse?
My power mirrors quit working, both of them. I don't recall if it was one 1st then the other or both at the same time as I don't drive it all the time. I seem to have a good switch and perhaps power at the plug. Since there's 91 fuses, relays, and circuit breakers, maybe someone's got some insider knowledge of the issue before I go trying each one individually. There's the possibilty that the mirrors are fused but not the main power? I have 1 12V reading in the 8 pin plug but since both are not functioning I suspect a circuit issue vs both mirror motors going out at the same time. Any help? Thanks in advance.
Old May 9, 2011 | 01:22 PM
RKSmith163's Avatar
My manual don't list a fuse for the mirrors either so it is on a circuit with something else as you have figured out. Is there anything else not working? That would eliminate the bad fuse theory. I will try to find it in my service manual.
Old May 9, 2011 | 01:48 PM
RKSmith163's Avatar
In my 2008 manual, it looks like fuse 56. Listed also as FRT TRN/HAZRD CTSY MIR
Then it goes through the BCM to the Left/Right selector switch and then to the Horizontal and Vertical switches on the mirror. I don't know if that will help but that is what the wiring diagram is telling me.
Old May 9, 2011 | 03:36 PM
Yes that helps a lot. I hope 06 is similar. Thank you, I'll check it tonight and report what I found for the board.
Old May 9, 2011 | 06:34 PM
RKSmith163's Avatar
They are labeled and numbered on the backside of your fuse box cover. I think all models are basically the same. There are a couple of small variations with the Alpha and the T.
Old May 10, 2011 | 05:20 AM
Well, no luck there. Not a fuse as of yet. The door plug was discussed in another thread of electical woes but everything else works like locks, windows, door chimes. I guess I'ma get a wiring diagram. I'm pretty sure the mirrors are in series, then there's that "which one" question. Still diggin and thinkin...
E-dragon
Jul 6, 2014 09:15 AM
kpaintner
Nov 3, 2013 08:07 PM
chesh97
Mar 13, 2012 04:32 AM
Major Tom
Jun 13, 2010 03:37 PM
rustic4
May 31, 2009 06:10 AM
