THE meaning of ACCELERATION!!!!
Old Nov 16, 2007 | 08:12 AM
Default THE meaning of ACCELERATION!!!!
ACCELERATION PUT INTO PERSPECTIVE
* One Top Fuel dragster 500 cubic-inch engine makes more horsepower (8,000 HP) than the first 4 rows at the Daytona 500.
* Under full throttle, a dragster engine consumes 11.2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same
rate with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to merely drive
the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric
water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of anarc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust
valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow
cylinder heads off the block in pieces or split the block in half.
* Dragsters reach over 300 MPH before you have completed reading this sentence.
* In order to exceed 300 MPH in 4.5 seconds, dragsters must accelerate an average of over 4 G's. In order to reach 200 MPH well before half-track,
the launch acceleration approaches 8 G's.
* Top Fuel engines turn approximately 540 revolutions from light to light!
* Including the burnout, the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid off, the crew worked for free, & for once, NOTHING BLOWS UP, each run costs an estimated
$1,000 per second.
0 to 100 MPH in .8 seconds (the first 60 feet of the run)
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
6 g-forces at the starting line (nothing accelerates faster on land)
6 negative g-forces upon deployment of twin chutes at 300 MPH
An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle onearth . . quicker than a jet fighter plane . . . quicker than the space shuttle.
The current Top Fuel dragster elapsed time record is 4.420 seconds for the quarter-mile (2004, Doug Kalitta). The top speed record is 337.58 MPH as
measured over the last 66' of the run (2005, Tony Schumacher).
Putting this all into perspective:
You are driving the average $140,000 Lingenfelter twin-turbo powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged & ready
to launch down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast
across the starting line & pass the dragster at an honest 200 MPH. The 'tree' goes green for both of you at that moment.
The dragster launches & starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums & within 3
seconds the dragster catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it -
from a standing start, the dragster had spotted you 200 MPH & not only caught, but nearly blasted you off the road when he passed you within a mere 1320
foot long race!
That's acceleration !
Just a little somethin to think about. Boy my Hummer is
Old Nov 16, 2007 | 08:32 AM
Muddydawg75's Avatar
Default RE: THE meaning of ACCELERATION!!!!
That brings a smile to my face....
but to the non knowing the Daytona 500 is a crappy comparison... the 505hp ZO6 has more HP than the Nextel Cup Cars do.... on a restrictor plate race...
Old Nov 19, 2007 | 05:18 AM
hilljob26's Avatar
thats cool
Old Nov 19, 2007 | 10:06 AM
SpeedNut's Avatar
Crazy stuff, makes you wonder what kind of insanity it takes to sit in a dragster with all of that going on.
Old Nov 19, 2007 | 10:33 AM
importkiller's Avatar
I think they still get better fuel mileage than my h3...lol
Old Nov 19, 2007 | 01:51 PM
ORIGINAL: importkiller
Old Nov 19, 2007 | 02:57 PM
you get crappy gasmileage because you are a dik....
Old Nov 19, 2007 | 02:59 PM
dik...and crappy....what the hell is on your mind?!?!?
Old Nov 19, 2007 | 03:00 PM
the pictures you emailed me of your overnight jail trip....
Old Nov 19, 2007 | 03:35 PM
good times....good times
