Market for Used H2 - Should I Buy Warranty?
Old Jan 24, 2018 | 10:35 AM
Jljordann922's Avatar
Default Market for Used H2 - Should I Buy Warranty?
Hey - new guy here. Looking at purchasing a 2004 H2 with 77k miles from a dealer within reasonable distance. I've read through what to look for but being not so mechanically inclined I get worried thinking of buying a 15 year old vehicle for $20k that could potentially have major issue soon after purchase.
This dealer offers an extended warranty which I would like to know if you think it is worth it and if it seems that it would cover most of any issues i should encounter. Below are the quotes which im sure are negotiable and what it covers. Thank you in advance.
Freedom Warranty
Drive 24 months / 30,000 miles $3480
Drive 36 months / 50,000 miles $3590
Drive 48 months / 70,000 miles $3700
1. ENGINE (Gas or Diesel): The following internally lubricated parts: pistons, pins and rings, connecting rods and bearings, crankshaft and main
bearings, push rods, valves, springs, replaceable guides, replaceable seals and lifters, rocker arms, shafts and bushings, timing gear, guides, chain,
tensioners and retainers, eccentric shaft, oil pump, intake manifolds, cylinder head gaskets, engine mounts and cushions, engine torque strut,
harmonic balancer, flywheel (flexplate) and flywheel ring gear, all pulleys. Engine blocks and cylinder heads are also covered if Mechanical Breakdown
was caused by an internally lubricated part or a part covered under this contract. All lubricated internal parts of the vehicle manufacturer installed
turbo-charger or super charger if selected on the Registration Page of this policy.
2. TRANSMISSION (Automatic & Standard): All internally lubricated parts, torque converter, and vacuum modulator. Also included: computer modules
and solenoids, transmission mounts and internal linkage. Transmission cases are also covered if Mechanical Breakdown was caused by an internally
3. TRANSFER CASE (4 x 4 or All Wheel Drive): All internally lubricated parts within the Transfer Unit including: bearings, bushings, sprockets, chains,
sleeves, and gears. Transfer cases are also covered if Mechanical Breakdown was caused by an internally lubricated part of a part covered under this
contract. Transfer Units are only covered if selected on the Registration Page of this policy.
4. DRIVE AXLE (Front and Rear Wheel Drive): All internally lubricated parts contained within the housing: axle shafts, constant velocity joints (CV
joints unless boot is damaged or missing),universal joints, flexible joints, drive shafts, locking hubs, locking rings, supports, retainer and bearings.
Differential housings, final drive housings, and trans axle housings are also covered if Mechanical Breakdown was caused by an internally lubricated
5. COOLING: Radiator, fan, fan clutch, and water pump.
6. AIR CONDITIONING: Compressor, condenser, clutch pulley, clutch coils, evaporator core, accumulator, receiver/dryer, orifice, expansion valve,
serpentine belt tensioner, temperature control unit, blower motor, air door actuators and motors.
7. ELECTRICAL: Alternator, combination turn signal switch, control modules, cruise control transducer, engagement switch and servo, distributor,
gauges, horns, starter motor, front and rear wiper motors, electric seat motors, electric window motors, power antenna motors, power door lock
actuator, washer pumps, relays, starter and starter solenoid, voltage regulator, window regulators and wiring harnesses for listed covered components.
8. FUEL SYSTEM: Fuel delivery pump, fuel injection pump (except on diesels), and metal fuel delivery lines.
9. BRAKES: Master cylinder, power assist booster, vacuum assist booster pump, wheel cylinders, combination valves, disc calipers, self-adjusters and
actuators.
10. POWER STEERING: All internally lubricated parts within the steering gear housing including power steering pump, main and intermediate shafts,
couplings, pitman arm, idler arm, tie rod ends and center link. The steering gear housing is covered if the damage is caused by the failure of an
internally lubricated part.
11. SUSPENSION: Upper and lower control radius, thrust and trailing arms, shafts, upper and lower ball joints, steering knuckles, stabilizer shaft,
linkage, track bar, kingpin, spindle and spindle supports, torsion bars, coil and leaf springs, and wheel bearings.
12. SEALS AND GASKETS: Seals and Gaskets are covered if the Coverage Starting Mileage, as indicated on the Registration Page, is less than
75,000 miles. If the Coverage Starting Mileage is between 75,000 and 125,000 miles then seals, sealing boots (unless ripped or torn), and gaskets are
only covered if seals and gaskets coverage has been separately purchased. If the Coverage Starting Mileage is greater than 125,000 miles, the
vehicle is ineligible for seals and gaskets coverage. Seals and Gaskets are covered in conjunction with a covered repair. Minor to Moderate loss of
fluid or seepage is not considered to have a mechanical impact on the vehicle and is therefore NOT considered a mechanical breakdown and thus is
NOT covered. Alternator Bracket gasket, Exhaust Manifold gaskets or gaskets of any kind related to the exhaust system or emissions are NOT
covered. Seals and Gaskets Coverage pertains to Covered Components only.
Old Jan 25, 2018 | 08:07 AM
calif phil's Avatar
I would say buy the warranty, the 48 month plan seems like the best value. Try and talk them down on the price of the warranty. I bet there is 50% profit in that price.
Old Jan 25, 2018 | 08:28 AM
Thanks - it does look like it covers a lot of stuff plus Im sure the price can be negotiated down. It is also transferable to the next owner for $100 if I ever sell it before warranty expires, which I'm sure some people would find comfort in.
Old Jan 26, 2018 | 05:44 PM
madmayo's Avatar
Are you buying this from a gm dealer. Or a dealer that will be doing the warranty work in house? Does thebwarranty go through a third party? My 3rd question is the one i would be very leary on. I got burnt once on a "third" party warranty. They will fix things if it relates to the safety inspection because they have to. But when the yransmission sh$ts the bed three weeks after your purchase. They tell you its "normal wear and tear". You'll have to fight to get anything fixed. That was my pleasant experience with third party warranties.
When i bought my jetta. I made sure to buy it from the vw dealer and the car cost a bit more but the warranty was great. Never an issue getting anything fixed and they would always wash it before they gave it back.
If its a third party warranty. I always say i dont want it and just focus on picking the vehicle apart and getting the price as low as i can.Then they usually tell you they cant do it for that price. Then i make sure i leave them my contact info and walk. They will usually call in 2or3 weeks if the vehicle hasnt moved with your price or a way better price than before. Just my two cents.
Good luck. The h2s are a pretty good investment compared to any other vehicle ive owned mine for 6-7 years and put 50k km on and its worth a few thousand more than i paid for it.
Old Jan 27, 2018 | 11:03 AM
LoJac963's Avatar
^I couldn't agree more. Third party warranties are junk IMO and you will fight like hell with them to get anything fixed. I almost guarantee the warranty is not through GM. I couldn't imagine a GM warranty on such an old vehicle which is bound to have some issues down the road. Not to mention many H2 specific parts are long but gone.
Old Jan 29, 2018 | 02:20 PM
It's a 3rd party warranty through Freedom Warranty I believe. I'm leaning away from it now and just want to find a clean vehicle. There's an 03 with about 60k miles I am eyeing but it is in Fl and I am in NY, so would have to order a mechanical inspection report.
Old Jan 29, 2018 | 08:50 PM
sycraft's Avatar
there is a GM warranty available- GM Protection Plan, I had one on my 2007 H3, uses all OEM parts, replaced Transmission, shocks and several other items before it expired.
JointCare1
Jul 6, 2016 09:01 AM
dwaddsy
Aug 27, 2012 10:35 AM
dammeinmarrtin
Aug 16, 2010 06:42 AM
sharphummer
Jul 23, 2009 08:52 PM
Herm
May 6, 2009 11:55 PM
