manifold exhaust question
Old Jan 26, 2015 | 02:07 PM
Dakota25's Avatar
Default manifold exhaust question
I'm looking at an 03 with a manifold exhaust issue. I'm told it's leaking. Is this is a big hard fix or not really?
Old Jan 26, 2015 | 04:26 PM
madmayo's Avatar
The manifold bolts are notorious for snapping the heads off on all 6.0,5.3 etc. motors. should have been a recall. My Avalanche had it. My H2 also. Front and rear bolts snapped on both manifolds and the passenger had a 3" crack in it. So I had my mechanic do it. Because the dipstick was rotted from running through the manifold he replaced that as well. So be prepared for that as well. As I've seen people post the dipstick tube can turn into a nightmare. My mechanic snapped it off at the block and had to fight it out. Which I believe led to my oil pump failure a few weeks later.
So is it a nasty job? Yes. If you're really lucky and mechanically inclined it's doable.
You have to remove the inner fender(s) to access manifolds
Remove remaining manifold bolts. And either hope there is enough shoulder to get a pair of vice grips on.
OR weld a nut to the stud. Which will harden the stud and make it hard to drill out if necessary. I believe you get one shot at this.
Spark plugs also need to be pulled
Don't let the dealer tell you it's not a big deal. Tell him to have it fixed or knock 1500-2000 off the price. I know it's high but there is some aggravation pay there.
Good luck in your search
Old Jan 26, 2015 | 07:05 PM
citiboy's Avatar
Read on....pics on post #6.
https://www.hummerforums.com/forum/h...d-bolts-33363/
Old Jan 28, 2015 | 08:58 PM
Signal25's Avatar
You can also use GM studs for a 4.3L V6 and spanner-grip nuts for about 1/2 of what the ARP kit will cost you.
Stud is GM PN:10182325
Old Jan 29, 2015 | 10:56 AM
2004H2's Avatar
Mine broke off too,took it to my shop where they were able to replace all but 1,it broke off in the block,then they snapped off the ez out.......trying to get it out....so far no noise.....to bad they do not, use anti-size at the time they install these bolts...Rick
Old Jan 29, 2015 | 09:50 PM
09 Black H2's Avatar
Took mine to Midas, replaced both manifolds and removed broken bolts, and installed new manifolds. Less than $500.00
Plus installed new bands on muffler heat shield that rattled
Old Jan 30, 2015 | 10:20 AM
madmayo's Avatar
Wow! That is cheap. New manifolds, bolts and labour? $500.
Midas had to lose money there. The manifolds had to cost over 500 alone.
Old Jan 30, 2015 | 04:34 PM
Manifolds @GMCdealer were approx $100 each with gaskets.
Old Jan 31, 2015 | 08:03 AM
badss98's Avatar
I Had the broken bolts also, Big pain in the *** with dipstick that also broke at block.Got everything repaired with beer and taps then replaced those crappy stock manifolds with gibson shorty headers. Runs great and sounds better too.
Old Jan 31, 2015 | 10:17 AM
madmayo's Avatar
Man it cost me 240 just for the passenger side. I'm assuming your in the U.S. By these prices. We get hosed on auto parts in Canada.
Poindexter
Dec 23, 2014 09:58 AM
ChevyHighPerformance
22
Mar 19, 2010 02:52 PM
Dragracer_Rob
Jul 3, 2008 09:09 PM
madmaxmyers
May 16, 2008 09:53 AM
2luke2
Mar 30, 2007 12:11 PM
