Lowering vs Leveling
Old Aug 1, 2007 | 03:42 AM
Default RE: Lowering vs Leveling
I'm NOT SURE!!! I know I had to order a "SPECIAL" setup that Ground Force has due to my rear air suspension thingy!!![8D]
Old Oct 9, 2007 | 12:28 PM
D VADER's Avatar
I guess this is what you get in the $345 Ground Force Kit for the H3. Add $50 S&H plus alignment. No mention of front springs. It's still not clear.
Genuine Ground Force Lowering Suspension SystemsKits.[align=center]This is a BRAND NEW in the factory sealed box kit of Ground Force Lowering Suspension SystemsKits.[/align]Fits 2006-2007 Hummer H3, Included Front torsion keys, Alignment cams, Rear blocks, Rear shocks.
Old Oct 9, 2007 | 10:58 PM
**** or get off the pot already!!!!![8D]
Old Oct 10, 2007 | 08:39 AM
That kit could be overkill D Vader if I understand what you want to do?? If, you are happy with the front height, and you want to lower the just the rear, you would only need the (a set of) rear blocks to space under theaxel and above the springs, and new longer shocks, maybey??? longer rear U bolts? This would lower the rear to appx level with the stock front. The front T Keys and Allignment shims would accommodate lowereing the front even further, and then you would need an alignment by someone cabable of following the kits new alignmant specs. So I guess it is a matter of how much drop this kit has in the rear?
I thought I saw somebody selling just a rear lowering kit, (blocks and U bolts) but I can't put my finger on it???
Old Oct 11, 2007 | 04:51 AM
D VADER's Avatar
ORIGINAL: Doc Olds
I would like to drop it at all 4 corners. Looks like the kits give you 1" in front and 3" in the rear. I assume that makes it level. I probably wouldn't do the install and alignment so the whole deal is rather pricey!!
GorillaH2
31
Sep 19, 2007 12:49 PM
BMoney5327
May 21, 2007 04:26 PM
BMoney5327
20
May 11, 2007 07:50 AM
HummerBlues
Sep 27, 2006 05:42 PM
kblethf
May 9, 2006 01:36 PM
