lower grille oem lights
is there anywhere to get just the button for the oem lower grille lights. installing some lights on brushguard and thought that would make a clean look inside the cab. thanks
the switch part #'s are 88963885 & 88963884 one has ann arrow pointing up (roof lights)the other has the arrow pointing down (grill lights) you have to order one of each they are made for either the left hole or the right hole. The switches cost me $27 each at the Hummer dealership. You will also need the pig tail to connect to the switch. The dealer wanted $35 each ,I found them on line for $16. google GM Part # 12101864
I found the round rocker switches work well. They are a little larger than the hole so i used a unibit to open up the hole. The switch I used, I got at autozone for about $5. It also has an LED in the top of the switch that turns on when the switch is on. The LED's comes in red or blue.
rascole
Dec 20, 2014 10:31 AM
SundownAudioNY
Sep 6, 2011 03:02 PM
gregaac
Jul 16, 2010 11:05 AM
gregaac
Mar 9, 2010 07:53 PM
