Buttons for off-road lights
Old Feb 4, 2009 | 11:40 PM
biggmittens's Avatar
Default Buttons for off-road lights
Does anyone know of a source for the dash buttons for the off-road lights? I don't really like the GM roof lights, but would like to get the "factory" buttons to control brush guard lights.
As well, I'd like the "GM" roof lights if they had 4 rather than 2 lamps, does anyone know when to get a "formed" roof light bar with 4 lamps?
Old Feb 5, 2009 | 12:13 AM
lucky19942001's Avatar
i love mine, it has 4 lamps that are piaa. i installed myself and had to drill the mount holes and run the wire down the pillar and pulled the center dash console off and punched out 1 of the wholes behingd the shifter and the swith that came with it fit perfectly. connected it all up. in all took me about 2 hours but i took my time and it was very nice out when i did it and i am not at all a car genious but have done some wireing myself on the hummer and just learn, i have done almost all my installs myself and its more satisfying. heres a pic of my ride with it and a factory pic. my wife paid $800 shiped on sale 2 years ago as a fathers day gift for me so since it was my first she made it special. the factory pic is from www.ecarboutique.com $995
Attached Thumbnails Buttons for off-road lights-dscf0423%7E.jpg   Buttons for off-road lights-light-bar.jpg
Old Feb 5, 2009 | 07:54 AM
SEARCH and you shall find all the answers weedhopper.
Aux Switches https://www.hummerforums.com/forum/s...light+switches
Old Feb 5, 2009 | 08:13 AM
civilengineerh3's Avatar
This also list the part numbers for both switches
https://www.hummerforums.com/forum/s...ad.php?t=14581
Old Feb 5, 2009 | 12:57 PM
hotrod's Avatar
I found the round rocker switches work well. They are a little larger than the hole so i used a unibit to open up the hole. You also need to take a small file and put a small notch in the side of the hole for a locating tab on the switch. The switch I used, I got at autozone for about
$5. It also has an LED in the top of the switch that turns on when the switch is on. The LED's comes in red or blue. I always run my own wiring. I used to do this stuff for a living.
On a secondary note to wiring.
I always use the switch to operate a relay located underhood and wire the switch to send ground to the relay. This way there is no chance of shorting out a positive wire and yes I still fuse only the + wires.
Unfortunatly LED's only work 1 way so I had to take the switch apart and turn the LED around so it would work.
I know this sounds like alot of work but I have more time and talent than money.
rojah247
Sep 9, 2018 09:03 PM
larry0071
Aug 27, 2016 03:37 PM
bobopotato
27
Jul 30, 2011 09:09 AM
CruisinCarAudio
May 25, 2006 04:14 AM
CruisinCarAudio
Dec 13, 2005 01:24 AM
