Low Tire Light aftermarket tires
Old Dec 12, 2011 | 05:39 PM
kujosp's Avatar
Jewjenk thanks for pointing me in the right direction.
Doc they did tell me not to run at 90 psi without load because of tire wear and discount tire looked up the recommended pressure for that tire as being 65psi, however something changed when corporate was on the phone after talking to GM and they then told me to run the tires at 50psi after they got all the information together.
It is a bumpy ride on a smooth highway.
Old Dec 13, 2011 | 05:36 AM
jewjenk's Avatar
Originally Posted by kujosp
Problem Solved:
Discount Tire contacted their Corporate and Corporate contacted GM corporate.
The vehicle set psi can be changed through software that most GM dealerships have access to.
The Value was currently set on that vehicle to an unknown value.
Corporate took my vehicle, Tire, and load capacity of the tire and came back that those tires on that vehicle should be set cold at 50 psi for everyday driving.
The vehicle was set by GM to 50 psi and all tires were raised to 50 psi
Low Tire pressure light is now off.
Dang I don't understand how this wasn't solved the first time. Oh, well glad to have everything working properly.
Learn something new everyday, I did not think that they would actually disable it, but to reset the system for higher values is new to most of us and great. I guess if you have the right questions and push for a good answer, you CAN get results.
This should be a learning curve for hummer owners and other suv owners who want to go to specialty tires.
Good luck................
Kinder82
Apr 4, 2013 08:30 PM
oman
19
Dec 19, 2011 06:09 PM
manwithnoname
19
Mar 14, 2009 09:13 AM
NIK1
Dec 8, 2008 11:44 AM
mrhaney
Apr 16, 2006 10:46 PM
