Loosing coolant , cant find the problem
Old Jul 24, 2015 | 05:29 PM
H2Miami's Avatar
Default Loosing coolant , cant find the problem
I didnt check the coolant for the last 5000 miles but Im sure even in Fl heat is not normal to have an empty reserve .
problem is I can find the leak . Oil engine and tranny is good so coolant is not going to another pan
Is there any common issue to look at (pump,radiator,heater,)
btw the truck didnt overheat , temp has been little less than 200 .
I realized the lack of antifreeze due to a mantenience inspection
Thx for any inputs
Old Jul 24, 2015 | 07:00 PM
yoymon's Avatar
I don't know of anything particularly common, id guess the radiator has a crack in one of its plastic tanks or a hose has a crack, maybe a slow leak that you don't see on the ground...slow for now that is, you don't see any wetness anywhere? look near water pump too
Old Jul 24, 2015 | 09:22 PM
H2Miami's Avatar
Did a double deep check to find a small leak in the water pump .
looks like a DIY job . Will start working on it next week
harder part will be to do the work under Fl sun with 100+ °
Old Jul 25, 2015 | 04:32 PM
calif phil's Avatar
Water pump gasket is probably whats leaking. Easy enough to fix.
Old Jul 27, 2015 | 07:59 PM
H2Miami's Avatar
Water pump was ... replaced also the termostate and Ac belt
happythree
Aug 5, 2015 02:50 PM
SSPLUM
May 27, 2014 06:08 PM
drtom
May 10, 2012 02:55 PM
sbsisco
Jun 23, 2008 02:17 AM
haiminger
Nov 26, 2007 08:07 PM
