looking to change differential fluid
Old Apr 24, 2008 | 07:50 PM
dwaxman1's Avatar
Default looking to change differential fluid
Guys I am looking to change my differential fluid for Royal Purple, Both front and back, what have I got myself into....... Easy, med or pain in the a$$?? By the way, never did it before, looking for pointers as I am not scared but could use some advice, not to pleased with Dealer right now...
Old Apr 24, 2008 | 10:55 PM
dizzy's Avatar
Default RE: looking to change differential fluid
I just changed both front and rear diffs to royal purple last week. Pretty easy job but that diff fluid really stinks,especially if you spill it while refilling. The rear is alot easier then the front as far as having alot more room. You will need approx. 2and a half litres for rear and 1 and a half for front. Torque both fill and drain bolts to 24 ft pounds. Take the fill plugs off before the drain plugs just in case you can,t get the fill plug off so you won,t be stranded if you couldn,t refill it. Fill both front and rear to almost level with fill hole.
Old Apr 25, 2008 | 05:39 AM
dwaxman1's Avatar
I may call on you for assistance..
Old Apr 25, 2008 | 11:52 PM
dizzy's Avatar
No Problem!
Old Apr 26, 2008 | 05:36 AM
dwaxman1's Avatar
Old Apr 26, 2008 | 09:41 AM
Muddydawg75's Avatar
I have one suggestion tomake life easier especially for the front.... get a small peice of hose ... I used 18" of5/16" fuel hose... it slips on the nozzle of the gear lube bottle and then you can have the bottle much higher.... 3/8" would probably work also...
Old Apr 26, 2008 | 12:22 PM
CG07SUT's Avatar
Any friction modifier or any other additives required for this change? What is the best or most common interval to change this fluid?
Old Apr 26, 2008 | 10:15 PM
I didn't add anything to mine... and I did the fluid change at 50,000 miles... In the past I have changed the diff lube once a year... I felt it was worth it being I had 5.13's in a 7.5" rearend...
Old Apr 27, 2008 | 08:18 AM
dwaxman1's Avatar
I am planning to do it next weekend, I wanted to this weekend but wonderland opened friday night and blah blah blah, it has been nice and my wife booked up my dance card, had no time, family time you know
No more Jeeps
Jul 2, 2020 03:37 PM
happythree
Mar 10, 2015 08:02 PM
2wheelmonster
Jun 3, 2010 10:06 PM
HummerGuy
Jun 6, 2008 04:18 PM
Nxsov180db
Apr 30, 2008 09:37 PM
