Light Bar "ON" with Brites!
Old Oct 22, 2007 | 08:22 PM
HumminNBoatin's Avatar
Default Light Bar "ON" with Brites!
Ok,
Hear is what I want to do. I love my XTC light bar but I would like it to come on with my brites but still have the seperate switch work for it at well. Does anyone have any idea how I can wire my fuse box safely so it can be done? And I dont want to hear about how it is illegal to drive with your light bar on. I know its illegal and I dont care. Just like you dont care if you are speeding 5 over.
I have noticed that the XTClight bar and Brites combined is awesome.
Eric
Old Oct 22, 2007 | 08:49 PM
GorillaH2's Avatar
Default RE: Light Bar "ON" with Brites!
Never knew it was illegal to drive with your light bars on
Old Oct 22, 2007 | 09:08 PM
mh307's Avatar
It is, most off road lighting is, b/c they burn the other drivers retinas out...lol. But they will no longer high beam you...
Old Oct 22, 2007 | 09:20 PM
Brad_P's Avatar
Its illegal on highways just to clear that up, incase of confusion. I would also like to know how to do this?
Old Oct 22, 2007 | 09:53 PM
tomp's Avatar
In order to do this correctly, you need a relay and tap into the high beam +12 volt wire to trip the relay. You should be able to use your existing relay for your light bar, but instead of wiring it to the switch for 12 volt supply - you will need to wire it to the 12 volt high beam wire.
Any stereo shop can get you fixed up really easily. In order for you to still use the switch and the highbeams to activate light bar, you should have them install a diode in case both HBs & swtich are on at the same time (This will provide circuit protection).
Old Oct 22, 2007 | 09:54 PM
tomp's Avatar
BTW, it's illegal to drive with your brites on as well so it's not going to matter if you flash someone your highbeams and you lightbar comes on as well.
Old Oct 22, 2007 | 10:01 PM
mh307's Avatar
True, but if a cop sees you w/ your roof lights on he prob will be much less happy then w/ just some high beams. Not trying to be a pansy, i run my off road lights all the time on the streets, they let me see much better, and as soon as i get some roofers, i run them too.
Old Oct 23, 2007 | 04:40 AM
hilljob26's Avatar
lets all do it,if everyone is doing it.......does that still make it illegal
Old Oct 23, 2007 | 08:33 AM
Tomp thanks for the heads up. I totally understand that concept of doing it.I am actually looking for the physical locations of where the connections should be made. I plan on doing this the comming weekend but just looking to see if anyone has already done this as it will save me a ton of time with the multimeter! lol
Thanks,
Eric
Hummer Guy's Avatar
ORIGINAL: hilljob26
Nope - just like speeding.
