leveling kit installed, but know...
Old Jun 4, 2007 | 01:10 AM
h3carlos's Avatar
Default leveling kit installed, but know...
Installed leveling kit, and 315/75-16 M/T's but know when I crank the steering wheel all the way, the tire hits the sway bar.....
Is this a common thing?
Thanks!
Old Jun 4, 2007 | 05:50 AM
naluboy's Avatar
Default RE: leveling kit installed, but know...
Yup, it's a common thing. I know it did with mine, in fact it still does a little. Did you get it aligned? When I first had the kit installed it rubbed quite a bit, but after I got it aligned, it rubbed less. You could probably add spacers to offset the wheels a little more. What kit did you get?
Old Jun 4, 2007 | 07:52 AM
HBH3's Avatar
This has to do with the 315s not the kit. It is very common, but an easy fix is to have a small piece of metal welded to the knuckle turn stops. I did that on my old Blazer and it worked just fine.
Old Jun 4, 2007 | 11:23 AM
h3carlos's Avatar
I got the ready lift kit, and I will be getting it aligned tomorrow
Old Jun 8, 2007 | 07:50 PM
novasaigo's Avatar
ORIGINAL: naluboy
Where do you get the spacers?
Old Jun 11, 2007 | 02:05 AM
naluboy's Avatar
You can get spacers at most automotive shops. It looks like this:
http://www.autoanything.com/suspensi...A2607A0A0.aspx
You just have to make sure it has the same bolt pattern 6 x 139.5 and the center bore is large enough to fit the H3's center hub. Also try not to get it to thick 1/4" at max. anything wider brings up some safety concerns...
Old Jun 11, 2007 | 03:53 PM
GreenH3's Avatar
Is there a performance reason they designed the H3 to be not level??
Old Jun 12, 2007 | 05:23 PM
naluboy's Avatar
The reason that was explained to me... Steering stability in the front when you're towing something or carrying a heavy load in the back...
myveryfastgt
Apr 10, 2012 12:37 PM
HummBob
19
Feb 17, 2008 11:11 PM
Gunner_45
Jul 24, 2007 10:16 PM
GarrettMoore
May 5, 2007 11:29 AM
diamondback
24
Jan 15, 2007 09:26 PM
